Old 08-10-2007, 11:24 PM   #1
ksjh1316
ksjh1316's Avatar
Best floor shifter
The TH400 is getting ready to go in but what is the best floor shifter to use with this tranny as far as ease of installation and reliability. Really want something that will also use the hole that my 4-speed will leave behind.
ksjh1316 is offline   Reply With Quote
Old 08-11-2007, 12:36 AM   #2
corn
Re: Best floor shifter
If you want to use the origional hole Im guessing Lokar or Genie will be your only options.
corn is offline   Reply With Quote
Old 08-11-2007, 01:05 AM   #3
ABLAZN
Oh..never mind....
ABLAZN's Avatar
I did the same thing that you are wanting to do . I ended up using the Lokar Cable Operated shifter. It was not cheap at $250, but I was able to install it using the factory shift boot. There was some fab work, and I still need to finish it up my mounting of the boot itself, but it is drivable and am pleased with it for the most part. Here is an installed picture.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 08-11-2007, 11:07 AM   #4
matthufham
b&m light truck mega shifter!
matthufham is offline   Reply With Quote
Old 08-11-2007, 11:29 AM   #5
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
I also use the B&M megashifter and realy like it. If you decide to go to a 700R4 later you can use it for that too
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
Old 08-11-2007, 11:45 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I am running the B&M Mega shifter on three different trucks. There is no problems and I can shift without fear of hitting reverse at 60 MPH. I change the "T" handles out for the B&M billet ball knob. I like the feel of that better than the "T".
piecesparts is offline   Reply With Quote
