Old 08-11-2007, 09:03 AM   #1
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
best way to run battery wires?
yesterday, going down my street, all the sudden everything shut off, and my truck stopped... i start to see smoke.. then i notice the battery wire is welded to the header.. and they got so hot...the arced in a few more places...
so im headed to kragans to get some new battery wires...was wondering if anybody had some ideas or pictures of the best way to run the pos/neg, wires... more importantly, how to run the positive wire to the starter without letting the header burn the insulation off the wire and arc it....
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 08-11-2007, 10:28 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: best way to run battery wires?
take straght off the battery to the frame bolt it to the frame then run it under the block it has never hit my headers yet.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 08-12-2007, 09:27 AM   #3
beaterC10
The factory uses clamps to attach the positive cable to the oil pan attaching bolts. It's a pain to replace the cable, but it stays out of harms way.
beaterC10 is offline   Reply With Quote
Old 08-12-2007, 12:55 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I ran my battery cables off of the battery down to the frame and had a rubber clamp placed there. That was followed up by the ground cable going to a bolt on the front of th ebolck (by the fuel pump boss). The positive cable was routed along the pan to the starter and I use the metal clip that came with the original pan bolts to hold it away from the headers. This has been a successful thing for many years and three trucks.
piecesparts is offline   Reply With Quote
