Old 08-11-2007, 11:55 AM   #1
1969k10stepside
WIW-4wd parts,2wd parts,gears,emblems,bucket seats,consoles,etc
Looking to clean out some extra parts and need to know the worth of it all so any opinions appreciated...
All the emblems are a pair
1) 4 Wheel Drive emblems-need painted
2) 8 350 Emlems-need painted for best results
3) Custom/10 emblems
4) Metal interior door panels w/out arm rest holes-One small bolt hole enlarged when removing
5) 5 lug rear axle shafts
6) 71-72 12 bolt axle housing and cover
7) 3:07 Ring,pinion,and carrier
8) Non tilt auto column
9) Non tilt 4spd column
9) Van tilt column-short shift lever
10) NP205 Skidplate and crossmember
11) NP205/Rockwell T-case crossmember
12) Corp. 12 bolt rear with 3:73s (From 4wd)
13) 3:73 ring,pinion,and carrier from dana 44 front axle
14) Closed Knuckle Dana 44 axle parts-Shafts,etc
15) Gauge Clusters,non tach.Oil pressure,gas level,speedometer,temp.
16) 69-70 Truck Bucket seats-Drivers side needs some foam work and new cover,passenger side needs foam replaced and a new cover.
17) Center Consoles-Correct for 69-72s.No cupholders-Needs 2 holes filled in center section
18) Factory Slider rear window
19) Door internal parts
***Will Start a new thread to sell parts in***
Thanks for the help on any pricing of some of these parts.I need to clear some room and need to know some prices..
Dustin
1969k10stepside is offline   Reply With Quote
Old 08-11-2007, 02:04 PM   #2
nplocoman
never finish start another
nplocoman's Avatar
Re: WIW-4wd parts,2wd parts,gears,emblems,bucket seats,consoles,etc
Interested in the 3.07 gears, but not sure what there worth.
nplocoman is offline   Reply With Quote
Old 08-11-2007, 06:59 PM   #3
w314speed
I'm interested in the np 205 crossmember and skid plate. I'll give $100 and first in line for any bumps!!!!!!!!!!!!!!!!!!!!!Thanks, Dan
w314speed is offline   Reply With Quote
Old 08-12-2007, 07:50 PM   #4
Shagn67
What are you taking from the truck? I am looking to convert my 2wd to 4wd and need a good rolling chassis/frame. I might be able to buy the whole package from you. I will have a good 2wd frame that has been converted to an ls1 and 4l80e....If you would like to trade.
Shagn67 is offline   Reply With Quote
Old 08-12-2007, 07:57 PM   #5
1969k10stepside
They are still in the 12 bolt rear but if they are in good shape like I remember them being,I'll sell the ring,pinion and carrier for $30 obo pluus shipping
I'll think about it.I might need the money after I get back from getting my jimmy.With the price of fuel,I might need the money
I'm taking my 4wd down to the frame/chassis to sell/store and selling off the axles,etc that I wont use if I keep it when going back together due to going to a 3/4 ton or 1 ton drivetrain...Not looking for anything in a trade,trying to cut back on my collection..
