08-11-2007, 12:58 PM | #1 |
Itty Bitty air cleaner for 1 barrel carbs.
I've been lookin around for an air cleaner like the one in the picture to use on my 1 barrel. I like the looks of those since they don't hide the engine. Where can I get one like that?
Luvlegs that is your engine. Hope you dont mind me using your pic.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
08-11-2007, 01:22 PM | #2 |
20' Daredevil (Ret)
Re: Itty Bitty air cleaner for 1 barrel carbs.
Here's one for VWs, also one for 2 5/8" neck, dunno what size you need.
http://www.dansperformanceparts.com/...ggyintake1.htm Small 4" Diameter Chrome Air Cleaner with paper element. 01-00-9012-0 CHROME MINI AIR CLEANER, STOCK VW CARB., 3" HIGH w/PAPER $ 6.95 01-00-9013-0 CHROME MINI AIR CLEANER, 2 5/8" NECK, 3" HIGH w/PAPER $ 6.95 01-00-9014-0 REPLACEMENT ELEMENT ,FOR MINI AIR CLEANER, 2-1/4" HIGH PAPER $ 3.95
08-11-2007, 01:25 PM | #3 |
20' Daredevil (Ret)
Ah, I posted too quickly -- a few more here...
http://www.trucknvans.com/Chrome_Air_Cleaners_s/143.htm
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-11-2007 at 01:26 PM. |
08-11-2007, 02:25 PM | #4 |
I bought one from Canadian Tire..cheapy parts store, I am guessing like a pep-boys or something? Try any parts place that stocks aftermarket air cleaners.
"You can take the man out of PA, but you can't take PA out of the man" |
08-11-2007, 02:26 PM | #5 |
Thanks. Thats exactly what i was looking for.
08-11-2007, 02:30 PM | #6 |
dont forget motorcycle parts either somtimes you can get creative and end up with some cool stuff
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
08-11-2007, 04:03 PM | #7 |
how cute...
08-11-2007, 05:40 PM | #8 |
I did it temorarily until I could get the offset aircleaner set up - finally have one, just need to get it cleaned and painted. I will be getting rid of mine in about a month or so.... it makes a lot of sucking noise when you step on the gas..... a lot! It stops as soon as you let of though and it does look "cute" - I think now that I have the HEI, even though it's still a one barrel, I need more air.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
08-11-2007, 06:55 PM | #9 |
I was wondering how the air flow was on it. Didn't know how restrictive it is. Not that I have a suped up 6 banger but i still dont want it to suffocate.
08-11-2007, 08:43 PM | #10 |
Active Member
I use the same filter on my 6 cylinder. When I put power brakes I had to remove the old breather and go to the small one.
Bought it at the local Auto Zone and I believe you can buy it at any auto parts. |
