![]() Join Date: May 2007
Alternator Wiring help please.
I know there is a lot of people that come through her if any of yall can help me figure this out please let me know cause I'm stuck. It's on the electrical board.
http://www.67-72chevytrucks.com/vboa...d.php?t=253447 Thanks ahead of time -Jason
- Jason ![]() ![]() |
Active Member
![]() Join Date: Jul 2007
Re: Alternator Wiring help please.
Not sure what kind of help you need or what problems you are having, but I wired my internally regualted alternator according to the schematic provided on the other thread. Didn't have any problems.
Just make sure that it's an internally regulated alternator. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
CJ if you read my post in your thread on the electrical forum in the last sentence I said there is more to it. Now in your post you said can anyone explain the in-line exciter diode. Then later you are talking resister. I can tell you that if you do not have an idiot light charging light then you will need a 75 ohm 3 watt resister in the sensing circuit. There is a huge difference between a diode and a resister so I assume you meant resister.
As far as I can tell from your pics you have an internally regulated alternator. As 68GMSEE says, just wire it like the schematic shows and it should work fine.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Is the plug the same as the old alt? If not does it still have the external voltage reg hooked up? The plug on an ext reg alt is more square. On a int reg alt it's more rectangle(like the one in your pics).
