Old 08-11-2007, 03:15 PM   #1
wazooz2424
bogging at 50mph
this is a odd symptom that happened last week and i have no clue what it could be.
69 c10 2wd
230 inline6
truck starts perfectly, idles perfectly and runs perfectly, up until 50mph. once i pass 50, the truck jerks almost like a fuel problem. jerks back and forth hard. if i take my foot off of the gas immediately, i can keep it running once the speed drops. if i keep the gas steady it will die, but starts up right away and idles again perfectly. below 50, i can floor the pedal without any bogging.
i noticed a torn up alternator belt, so i replaced that. did not fix the issue.
i am clueless. any ideas?
wazooz2424 is offline   Reply With Quote
Old 08-11-2007, 03:50 PM   #2
sb69chevy
sb69chevy's Avatar
Re: bogging at 50mph
This may not be it, but...when mine does that, it's been the fuel filter.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 08-11-2007, 03:53 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
I had a similar problem with mine and it was because the fuel pump suction hose was collapsing.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 08-11-2007, 03:55 PM   #4
lamar
lamar's Avatar
I vote fuel filter or fuel pump.
72 C-10
lamar is offline   Reply With Quote
Old 08-11-2007, 03:59 PM   #5
sb69chevy
sb69chevy's Avatar
I have so much junk in my tank that I have to run an inline and in-carb filter. It's the in-carb filter that needs changing when mine does this.
Old 08-11-2007, 05:16 PM   #6
wazooz2424
thanks everyone. i was thinking fuel also, but the way it runs at low speed (below 50) threw me trough a loop. i do not have an inline, so i will check the screen in the carb and replace the suction hose. i guess this ethanol fuel is finally starting to clean my tank and screw things up.
Old 08-11-2007, 05:35 PM   #7
cdowns
cdowns's Avatar
try taking your gas cap off. it could be your cap isnt venting properly//could also be the intank filter screen on the fuel pickup
Old 08-11-2007, 06:54 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are you running E-85? That may be the problem right there.
On a side note... you probably have a 250, not a 230... unles you swapped out for it, the 230 wasn't installed in these trucks.
Old 08-12-2007, 08:29 AM   #9
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Could be a float problem, at high speeds your float bowl could be running dry.
No gas = bogging, a little gas = power, no gas = etc... jerking back and forth
Carb rebuilds for these 6 cyl are very cheap ($10 or less) and very simple.
Plus it gives you an opportunity to clean 40 years of gunk out of there.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 08-13-2007, 12:38 AM   #10
bedsled71
bedsled71's Avatar
my truck use to do the same thing and i could never figure out what it was... then i put in a v-8 and havent had the problem.... i wish my 250 was still in there!
bedsled71 is offline   Reply With Quote
Old 08-13-2007, 02:22 PM   #11
ohenryoh
Check you plug wires too, make sure they are not arching.
ohenryoh is offline   Reply With Quote
Old 08-13-2007, 06:37 PM   #12
71tahoe
71tahoe's Avatar
I drove a, please excuse my French, Dodge 880 in convoy through Texas and Arkansas one summer. On the way back it was quite hot by the way. Same symptoms and it turned out to be a fuel filter keeping enough gas from getting to the fuel bowl at higher RPMs. Basically the engine would drain the carb dry.
71tahoe is offline   Reply With Quote
Old 08-13-2007, 08:26 PM   #13
Premium72
Premium72's Avatar
yeah put a inline filter on that bad boy somehwere. i had to put 20 on my 49 coupe..worekd like a charm..
i also had some valve problems on my 235 at one point. they were adjusted wrong. if the filter doesnt work, try adjusting the valves.
Premium72 is offline   Reply With Quote
Old 08-13-2007, 11:32 PM   #14
Billla
Billla's Avatar
you'll need to flow ~20% more fuel at speed; if the carb isn't set up for E85, it's not gonna happen.
Billla is offline   Reply With Quote
