Old 08-11-2007, 10:15 PM   #1
project 67 sub
project 67 sub's Avatar
Question lowering question.............
does anybody know of a company, or any imparticular person on here that makes, or can make 3" lowering blocks for the 60-72 chevy trucks, and how much are they? or how much would someone charge to make me some? i need to get a set for my 67 burb.
p.s. thanks in advance
project 67 sub is offline   Reply With Quote
Old 08-12-2007, 07:16 PM   #2
royo
royo's Avatar
Re: lowering question.............
why would you want 3 in i know they make a 2 in
nickle and dime
royo is offline   Reply With Quote
Old 08-12-2007, 08:07 PM   #3
project 67 sub
because i want to be able to get the back as low as i can until i can get a
4-link to run with the off the front of the axle airbag brackets and bags
Old 08-12-2007, 09:58 PM   #4
royo
royo's Avatar
I guess you could stack a 2 in and a 1 in block also get a new u bolt made at a spring shop but have you measured the distance between the trailing armand the bottem of the brake drum and how close it will be to the ground that is if it is coil spring rear if it is leaf spring a block can be bought anywhere
nickle and dime
Old 08-12-2007, 11:24 PM   #5
project 67 sub
yah it is a coil spring rearend, im going to be runnin 20's anyways so it doesn't matter to much how low the trailing arms will be compared go the bottom of the drum. because this will only be a temporary setup untill i can get some money for a 4-link(possibly a kp components bolt in unit). yah i guess i could always stack a 2 inch and a 1 inch block together for now and have my local spring shop make me a new set of ubolts.
Old 08-16-2007, 05:42 AM   #6
knightlife
Dark Heart Motorsports
knightlife's Avatar
there are 1,2, and 3...
here:
http://www.andysautosport.com/chevro...kits/belltech/
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
Last edited by knightlife; 08-16-2007 at 05:43 AM. Reason: they make a three, and Im retarded...
knightlife is offline   Reply With Quote
Old 08-16-2007, 02:48 PM   #7
project 67 sub
Originally Posted by knightlife View Post
knightlife:
thanks for the link, but those wont work because i have a coil spring rearend
