09-25-2002, 02:31 PM | #1 |
Like a Rock!
Header collector gaskets -replacing
When you remove the 3 bolts, do the old gaskets slip right out or do you have to pull the the pipe back?. Is this pretty easy or do I have to loosen other things to replace the gaskets?. Thanks
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
09-25-2002, 02:52 PM | #2 |
Its cake, probably the easiest thing on the truck to change, as long as the bolts aren't rusted beyond repair. Just jiggle the exhaust and the gaskets practically fall out.
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
09-25-2002, 02:54 PM | #3 |
72 Cheyenne
It's easy, take the 3 bolts off and just move the pipe back just enough to get the gaskets off and on, you shouldn't have to take any other bolts off, maybe loosen one or two but I dought it, put a crate or something under the pipe to hold it in place before you take the bolts out.
09-25-2002, 03:06 PM | #4 |
Like a Rock!
cool, I thought the pipe was forced into the collector!
