08-12-2007, 01:13 PM | #1 |
Anyone know a trick for searchs?
I have a 97 LT1 I am going to put in my 68 and I know there are many threads here about this subject. I am having trouble with the search feature not letting me search for "LT1". Anyone have any tricks so I can find this information?
08-12-2007, 02:09 PM | #2 |
Re: Anyone know a trick for searchs?
Here's a trick that should work:
Go to www.google.com To the right of the search box is "advanced search", click on that. Where it says "Find Results with all of these words" type "LT1" Where it says "domain" type in 67-72chevytrucks.com Click on the "Google Search" button back toward the top of the page. This will only search on www.67-72chevytrucks.com and you can search for those shorter strings that the board search won't let you do.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-12-2007, 07:18 PM | #3 |
Parts and more parts
What are you looking for? The LT-1 should one of the easier installs. No distributor problems, the exhaust should be easy and the linkage is basically the same as any fuel injection install. If nothing else look on Street and Perfromance's website, in their tech sectyion and click on LT-1 for info. They even give out DVDs with ideas on install options.
08-13-2007, 08:58 PM | #4 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
08-14-2007, 08:26 PM | #5 | |
08-14-2007, 08:38 PM | #6 | |
