![]() Join Date: Nov 2004
4 core radiator and thermostat...
Looks like my A/C install in gonna take a hike in price again. I have a 3 row radiator in my truck with vintage air A/C now. I drove the truck on a 90 mile round trip yesterday and even on the interstate with the A/C off the truck was running at 200 and as soon as I turned the A/C on it jumped to 210 degrees. I'm not so much worried about my motor running that hot, but I don't want to fry my 700R4. It jumped to 210 running down the highway at 70 mph... not good! Although, it never did get above 210... BUT my engine started pinging up hills when the temp was at 210, no more pinging when it dropped to 200. My timing is set at 12 degrees BTDC.
On my way back I found a super nice 69 or 70 (can't remember now which) swb fleetside with factory A/C and automatic for sale in Easley SC, on Hwy 123. I popped the hood and it had an enormous radiator. The truck looked very stock and original under the hood, so the 4 core is much bigger than the 3 core? It also looked like it had larger holders as well, the clamps at the top and the bottom. Autozone sells an automatic one for about $190. People with A/C... are you running a 4 core? Do you have an automatic (big heat adder!) Also, what thermostat are you running. I think mine is a 185. Thinking about bumping it to 190. Is my timing maybe a little high too? Truck runs great when it's running "cool." Electric fans will also be an option, but I'd prefer to have a proper capacity radiator first and not use the electric fans as a band aid. ![]() Also, it was about 102 outside yesterday! ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 02:02 PM. |
Re: 4 core radiator and thermostat...
Basically the 3 row is 75% as thick as a 4 row. 25% larger I guess. If you want to maintain a lower temp, like 180, and you live where it gets hot. You will most likely need a 4 core/row radiator. I am about to do the same thing.
If your 3 row needs a good cleaning (rodding out) it might help some. I run a 180 thermostat, 402/auto, 3 row radiator, inop a/c, cools pretty good. I am sure a working a/c will drive the temp up. Also you will need those 4 core radiator brackets with pads. They are pretty cheap new or used. Last edited by Texasdeere; 08-12-2007 at 04:24 PM. |
That's about what I figured!
What sucks is that my 3 row radiator is only 2 years old ![]() That can be eliminated as a problem, it was very clean when I drained it to install the A/C a couple months ago! The thermostat is working, it opens and cools to the proper temp when I'm not running A/C, but once it gets "hot" it's hard for the truck to get back to "cool." I like lots of options/opinions, so keep 'em commin' ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-12-2007 at 04:33 PM. |
#4 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
My truck never overheated with the oem 3-row radiator, which finally went bad a couple years ago. I replaced it with a 4-row -- same dimensions, just a bit thicker core. Thermostat is 195, that's all I've ever used. Oh yeah, auto trans too.... With a shroud and a good clutch fan, you should be okay.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-12-2007 at 05:03 PM. |
^My bad, flex fan is long gone. There is a "factory" 7 blade clutch fan under the hood now
![]() Did your truck have A/C too?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-12-2007 at 05:11 PM. |
20' Daredevil (Ret)
OK, 7-blade is good
![]() I have factory A/C but the front compressor seal failed several years ago ![]() 210 isn't too hot, seems like spark knock may be your only problem. It shouldn't be enough to bother the trans either -- might need a trans cooler if you don't already have one. And 12 degrees doesn't sound like too much advance either... maybe your engine is just more susceptible to pinging.
#7 | |
![]() Definitely worth a try! I assumed you had the stock fan set up. Last edited by Texasdeere; 08-12-2007 at 07:00 PM. |
i had factory ac with 350/2004R and a 3core rad never had a heating issue on the open road even with heavy fleamarket loads the few times it got real hot on me it was near 100 with stop and go traffic backed up for miles at less than 10mph(atlanta and new york city rush hours gotta lovem) i had factory clutch fan and shroud
Do you have auxilliary trans cooler? Either inline with rad or stand-alone could take some of the heat out of the system. Also, is your trans working right? If lock-up clutch doesn't work right, it will run hotter. If the trans has just started slipping or has bad TV adjustment it will overheat. If you don't get hotter than you describe, it is probably OK, just something to keep in mind. Timing needs to be right when at max advance, not all that critical at idle. Vacuum advance could be a minor factor as well, if it advances too much. If you're pretty sure everything else is up to snuff, a big trans cooler would at least protect your 700R4. But when all is said and done, I use a four-core.
huh ???
My 72 came factory with air and a 4 core rad. When i installed a 396 i left the 4 core and ran a 165 stat. Never had a problem with the 700R4 until the TV cable got messed up and I blew the trans...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#11 | |||
Union Electrician
You can get a aluminum rad off ebay for just about $25-30 more( I got mine for right at $230 shipped) than the autozone 4 core stock style,shipped to your door, that is the way I went.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#12 | |
I actually bought a cooler off ebay, but it wouldn't fit behind my grill so I never installed it ![]() I think I'm going to get a 4 core radiator and one of those radiator looking trans coolers and put it in front of the condenser.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 10:14 AM. |
#13 |
Take a close look at the Aluminum 2 row rads at Summit. A 2 row aluminum rad will out perform a 4 row copper rad. That is no exaggeration. I work in a climate control test lab for Visteon and have tested radiators, evaporators, condensers and compressors for both production and prototyping. Aluminum is the way to go for maximum cooling.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#14 |
They also sell a frame mounted tranny cooler, with your condensor in front of the radiator a frame mounted may be your only choice. I run my cooler solo from the radiator, it is a 12X12 and I ran tranny cooler hose along the frame rail right to the cooler. I agreee with the above posts on the aluminum radiators, and adding a cooler either way ou go.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#15 |
^What brand cooler did you buy and where exactly did you put in on the frame???
Does it get enough air flow down there? Pics? ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 11:50 AM. |
#16 |
Would this be a good place to mount a cooler? Would it get enough air flow? I would mount it inline with the radiator cooler.
What sucks is that out of all the trucks, it appears that the 67/68's have the smallest grill opening.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 11:51 AM. |
#17 |
Spanked once
![]() Join Date: Oct 2006
Not to step on Old Iron here but this is the one I am going to use in the 24 oz variety.
http://www.jegs.com/webapp/wcs/store...60008_-1_10535 |
#18 |
I bought this off of ebay last year and it won't fit behind my grill, especially with the condenser in there now, and it's 18" long. Where were you planning on mounting yours?
Would it get enough airflow if I mounted this cooler in the position shown above? I didn't drive the truck today, but I think it will fit...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 12:07 PM. |
#19 |
Spanked once
Trans cooler is not a good name IMO , it is more of a temperature stabilizer. Here in the north when it is winter the lines run thru the radiator to help warm the trans as soon as possible. Where you are at in the summer and here they are normally used as an auxiliary help for towing packages or extremes to help stabilize the tranny temp. I am mounting the type you have back by the trans inside the frame rail.
#20 |
With everything already installed in the truck and my dual exhaust, I don't think I could get mine inside the frame rails. So I guess it would be OK to install it on the crossmember.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#21 |
The blue one you have is designed to be mounted along the frame. Mine is an Autozone cooler (don't remember what brand) My grille was out at the time, I mounted it in the lower passenger side corner of the center "cut out" of the core support. (If you were to reach behind it, your hand would be touching the radiator). Sorry, no pics. I have a digital camera, I just don't use it like I should.
#22 |
I've learned a lot from this thread!
I'm going to check on mounting places for my heat exchanger ![]() Next up (even if the tranny cooler keeps the truck cool) will be to run a 4 core radiator. It gets too damn hot down here and I drive my truck too much to not do it. Thanks so much for all the help!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2007 at 02:21 PM. |
#23 |
Spanked once
My 71 came stock with the 4 core and although it does not leak I am trying to find someone to re-core it before I stick my 383 with air in the truck.
#24 |
After using a cooler, I will never run another truck without one. The guy I use for tranny work says keeping it cool, espically in the south is crucial. I don't run a temp. gauge on my transmission, but I don't think it is a bad idea for the piece of mind. Non-working A/C guys want a SUPER cooler for their transmission? Plumb the lines through your A/C condenser! That's what I was going to do until I found the one I currently use. My truck is factory A/C cab, it does not work, I'm gonna do under dash a/c and shave the firewall.
#25 |
Old member
67ChevyRedneck ,
You can take the cooler to Clines in Greenville and they will make the lines for you. They are very good. Prices are good too! Another option is make a bracket for it to fit between the frame rails up front.Make it so the cooler is hanging between the front ends of the frame for protection. You could even get some sheet metal and make a scoop to direct air to it. Not a trans cooler but a power steering cooler my dad gave me years ago. Same differance though. If you need help on it call I'm just outside of Easly in Liberty. I'm sure we can figure something out on it. 864 843 6934 I'm on nights this week but off all weekend.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 08-13-2007 at 03:57 PM. |
