Old 08-12-2007, 09:43 PM   #1
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Part numbers needed
I need part numbers for the chrome cargo light housing, lens gasket, lens and the switch for inside the cab.
Thanks in advance
Jason
jay_shy is offline   Reply With Quote
Old 08-13-2007, 01:30 PM   #2
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Re: Part numbers needed
Does anybody have part numbers, or a book to look them up. Thanks
Jason
Old 08-15-2007, 04:56 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Not sure if you found them. Is this is what you were looking for?
http://www.brotherstrucks.com/products.asp?dept=605
68gmsee is offline   Reply With Quote
Old 08-15-2007, 05:59 PM   #4
Andy4639
Old member
Andy4639's Avatar
I don't have a factory inside light but I have the cargo light. This is a orignal cargo light assembly.
Lens#5961500
Cargo housing # 5961568 this number was on the backside of housing.
Inside the housing behind the bulb is
GUIDE 12
SAE R 69
Hope this helps it's all the numbers I can find on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
