Can't wait to retire!!
Info needed on body bushing kit
Hi all, I have a body mount kit that came with my Blazer and after doing some research, I've found that it is a Prothane kit. It has nothing to tell me which bushing goes where, can anyone help? The kit number is a 7-105 and I have the numbers of all the individual pieces, but that's it.
Any help would be appreciated. Thanks in advance.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Re: Info needed on body bushing kit
I just finished installing one on my Blazer today. It was an Energy Suspension kit #3-4110 but may be close to the same as yours.
From front to back there are 6 mount positions on each side (this includes the radiator ones). Positions 1-radiator uses the same bottom rubber as 3-6. Position 2 uses the thickest rubber between the frame & body. Positions 3 thru 6 all use the same rubbers...Now is all that clear as mud! This hard to explain without showing you a pic. I don't have a scanner here at home, but will scan the directions & info tomorrow morning at work & post here. It has all the sizes listed of each rubber, sleeve, & washer for each position.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 Last edited by fun in dirt; 08-12-2007 at 11:24 PM. |
#3 | |
I hope this turns out big enough to read
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Thanks FID, that definitely helps.
