08-13-2007, 01:07 AM | #1 |
Spicer vs moog parts?
Going to starting gathering parts for a front end rebuild this fall (lower temps!). Going to buy my stuff through RockAuto.com. I was dead set on all moog parts (except for control arm bushings), but they also have Spicer parts available too. I have heard good things about them and even a few that said they were better than the moog parts. Are the problem solver parts really better or what?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
08-13-2007, 01:34 AM | #2 |
Garage Queen Material
Re: Spicer vs moog parts?
i'll be buying moog for any parts i cant get from energy suspension. havent heard of spicer before. i plan on doing this same thing before the end of the year. maybe when its my turn you can come over and help me out
08-13-2007, 01:47 AM | #3 |
I may wait till the new year then, so you can help me!
Just doing some price checking and the difference isn't really that great. The moog parts look exactly like the spicer parts. Really want to know what the "problem solver" tag is supposed to be...
08-13-2007, 02:22 AM | #4 | |
would look real good with the new wheels |
08-13-2007, 11:43 AM | #5 |
This says absolutely nothing about the parts in question... just some additional information to chew on.
Moog is a brand name of Federal-Mogul. Spicer is a brand name for Dana. Both companies are operating under Chapter 11 bankruptcy. http://www.fmoclaims.com/ http://www.dana.com/reorganization/ Okay, now to your question. I've always used Moog front end parts because that is what my local O'Reilly store stocks. I have ordered Moog front end parts from RockAuto before too, but you never know exactly what you will get. It seems the same Moog part number can come from different factories or at least from different casting molds. An example is the lower ball joints on my truck. I ordered them from RockAuto. When I got them, the boxes looked a little different, but they had the same part number. I open them up, and one ball joint is knurled where it goes thru the control arm, the other is smooth. I call RockAuto to ask why they sent 2 different parts, and they said something to the affect that design changes or revisions to the parts is why sometimes they are different. They probably sent an old stock part with a new stock part. I could have sent the parts back, but decided to save the hastle and just used them. They both fit fine. Now had I bought these ball joints locally at O'Reilly, I would have looked at the part right then and there and made sure I got two that looked the same. And if they didn't have two identical parts in the store, they can get them from the local wharehouse in a day - no charge. As for 'Problem Solver', that basically means the part should exceed OEM design specs. Things like larger bearing surfaces, thicker castings, stonger materials, higher durameter rubber, etc.
- Greg |
08-13-2007, 01:23 PM | #6 | |
454, thanks for the info. I'll stop by the local orielly's and see what they got.
08-13-2007, 09:34 PM | #7 |
BAD BOW-Silverado XST
My truck destroyed two sets of u-joints before I installed a Spicer. The spicer is bigger. I have no beef about putting my foot in it.
08-13-2007, 10:38 PM | #8 |
Junior Member
I didn't think Spicer made suspension parts. I thought they were only in the driveline (ujoints, etc..) biz. I'm a Moog guy for ball joints and tie rods unless I'm desperate. Spicer definitely for ujoints.
72 C10 Long Bed, Vortec 350, Muncie M20, 3.73 Posi 79 Camaro, Vortec 350, Muncie M21, 3.90 Posi 07 BMW 328i, Wife's |
08-13-2007, 11:17 PM | #9 |
i have all spicer parts in my front end. they also make the cheapo autostore brand types, i forget the name mine were.
08-15-2007, 12:37 AM | #10 | |
Insert Witty Text Here
IMHO, it needs to go another inch lower in the front. It sits dead level, but the difference in fenderwell heights front to back makes it look like the front sits higher than the back. Slonaker |
08-15-2007, 02:13 PM | #11 | |
I just looked at your pic page. So the bottom pic is 2.5"/4" drop, right? If so, I'll defenitely want to look into getting the front another 1" or so.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 Last edited by C&C Chevy; 08-15-2007 at 02:17 PM. |
08-15-2007, 10:45 PM | #12 | |
-Jeremy
79 Jimmy slammed AKA James Down |
08-16-2007, 12:06 AM | #13 |
Gone Fishing
They are both very good products. I have sold both in the past. Spicer/dana make some called perfect circle I believe that I have had under my 68 for 8 years now with no probs. Moog is also very good. It just comes down to personal preferance. Moog will also cost more than the spicer
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
08-16-2007, 12:38 AM | #14 |
Don't know if it's relevant but I bought Moog ball joints for my 99 Cougar, installed and torqued them to spec. set out on my way from Minneapolis to Indianapolis to see a Formula 1 race. got to Menomine Wisconsin when the steering wheel got really loose, so I pulled over and discovered that all 3 nuts had fallen off and I was hanging on by a thread (not good on I-94 doing about 95mph) so I found a shop to weld the nuts on and made it to the race.
The ball joints were good quality but the whole situation left a bad taste in my mouth for Moog. I know a little common sense would've told me to locktite them but I had planned on (and eventually did) making tube control arms so I wanted to be able to break down the whole setup easily and the Moog instructions specifically said that I didn't need any kind of thread locker. |
08-16-2007, 09:57 AM | #15 | |
Slonaker |
