Old 08-13-2007, 01:14 AM   #1
PrerunnerRob
PrerunnerRob's Avatar
Motor mounts and steering finally done!
So I finally got the motor mount made, and the rack n pinion hooked up to the steering column. Here are some pictures:
My friend George tig welding my mounts
Freshly ground
Yes, everything clears!
Steering hooked up
Steering was super easy to connect to the original column too, I shortened how far the colum sticks out past the firewall to lessen the angle on the upper steering universal joint.
And...........I do AC for a living, so I had to have it!
PrerunnerRob is offline   Reply With Quote
Old 08-13-2007, 01:17 AM   #2
PrerunnerRob
Re: Motor mounts and steering finally done!
Oh, and thanks again to Chiefrocka for recommending the master cylinder I am using, bolted right up no preblem, set up for disc front and drum rear. Sweet!
Old 08-13-2007, 04:22 AM   #3
L0WRIDE
L0WRIDE's Avatar
nice work dude!!!
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 08-13-2007, 04:28 AM   #4
poorboy
poorboy's Avatar
Looking good.
poorboy is offline   Reply With Quote
Old 08-13-2007, 11:33 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Lookin good man......looks like you just might make it to the BBQ !!!!
You actually gonna run A/C...or are you pump'n air ??
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-13-2007, 11:36 AM   #6
PrerunnerRob
Originally Posted by poorboy View Post
Looking good.
Thanks again for the AC stup, I am actually picking up all the r134a conversion stuff today.
Old 08-13-2007, 11:39 AM   #7
PrerunnerRob
John
A/C! I dont really care how fast this thing is to a certain degree, but I am going to spoil myself with a nice cool cab on hot days.
I have this guy for the air issue
I can't make it to the bbq, I found out it is on the same weekend that my friends wedding is on that I am in. Definately next time!
Old 08-13-2007, 12:15 PM   #8
teejay65
Hi,
I missed Chief's recommendation on the master cylinder...I have a 65 SWB..383/700R4...am converting to discs in the front, drums in rear...what do I need.
TeeJay
teejay65 is offline   Reply With Quote
Old 08-13-2007, 12:50 PM   #9
poorboy
poorboy's Avatar
No problem. I'm glad we were able to get it to you. Glad it's being used now instead of collecting cobwebs.
Old 08-13-2007, 08:42 PM   #10
PrerunnerRob
Originally Posted by teejay65 View Post
Hi,
TeeJay
Its from a 1974 Monte carlo, with manual brakes. Less then $50 including the core charge!
Old 08-14-2007, 12:10 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I still have the 74 GM master that I am not using...if anyone needs one...
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-14-2007, 11:23 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
You can use a master from a Truck also. They are pretty much all the same in the 70's. The bore's might be bigger in the trucks for more stopping power.. I used the whole power brake booster from a 79 GMC Truck with a master from a 75.. Some fab work is needed to use the later booster.. And if you look at the top of the bracket in the back, it would be nice to cut that off seeing you can't use it..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-14-2007, 11:58 AM   #13
hewlett2002000
hewlett2002000's Avatar
chevy fleetside i like the way you ran your brake lines. any chance of some pics of the line routing closer to the front or even a description where they run in the front?
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-14-2007, 09:22 PM   #14
Chevy Fleetside
thanks,
John
Well seeing I took the truck apart I don't have the lines in place anymore. They just ran down to the porportioning valve. I was going to put the new one under the cab and run my lines back againts the firewall. I looked but didn't have a better picture of it then that...
I did a little searching and came up with this picture. It shows a bit more. I really would not advise running your brake lines like this as they could crack from moving around so much..
Old 08-28-2007, 12:49 AM   #15
L0WRIDE
L0WRIDE's Avatar
hey prerunnerRob hows the 63 coming on made any progress???
62 HARDTOP NOVA
Old 08-28-2007, 01:18 AM   #16
3speed 6cyl
3speed 6cyl's Avatar
clean fabrication work!
3speed 6cyl is offline   Reply With Quote
Old 08-28-2007, 04:16 AM   #17
hewlett2002000
i got a question....... why are you using the rack and pinion? i know nothing about it so im just wondering what the advantage is over stock or power steering. if thats a stupid question im sorry but i had to ask.
thanks,
John
Respect:
Old 08-28-2007, 09:51 AM   #18
Chevy Fleetside
thanks,
John
One thing about rack and pinion is it is more responsive then conventional steering.
Old 08-28-2007, 11:05 AM   #19
PrerunnerRob
I have to use a rack and pinion due to the crossmember I built. I would have liked to retain the original stuff, but it would have never worked. I'm hoping to have most of my crossmember complete by this weekend, I'll post a ton of pics showing it.
Old 08-28-2007, 11:16 AM   #20
hewlett2002000
how much did it cost you and how much trouble was/is it to install? im actually designing a whole new suspension system front and rear for 64-66 trucks and maybe others later, but i hope you understand me not going into detail because i dont want my invention copied. i got it semi drawn out on paper but not completely. when i get it on paper im gonna have some of my hot rod buddies look it over. it will be a while before i build a prototype because of lack of funds.
Respect:
Old 08-28-2007, 11:53 AM   #21
PrerunnerRob
Rack and pinion was $100 from ebay, and all the other materials were scrap from the local steel supply, i would say about $70 at most. Steering setup was around $170, and I still have to make steering adapters.. Good luck on the invention, I got my idea from mine from Porterbuilts. Mine is not nearly as pretty or refined, but is strong and safe.
Old 08-28-2007, 12:06 PM   #22
Lemondrop63
Lemondrop63's Avatar
Those motor mounts are really nice. Real clean fab work.
This one time at bandcamp, in my c10, I ran over the girl hiding the flute!
http://67-72chevytrucks.com/vboard/s...d.php?t=255141
Lemondrop63 is offline   Reply With Quote
Old 08-28-2007, 04:15 PM   #23
PrerunnerRob
Thanks, its nice to get some appreciation for many hours of fabrication spent on small parts.
Old 08-29-2007, 03:09 AM   #24
Stepside65
Still Truckless!
Stepside65's Avatar
Gotta agree. That is one nice set of mounts. Wish i could tig like that.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
