Old 08-13-2007, 12:27 PM   #1
1bad chevy
1bad chevy's Avatar
500-472 caddy installation question?
who has done this and do you have pic's of your home made motor mounts if so would like to see them i'am attempting to do so as i post this. ya i know why? will be the next question i have a problem with the 355 that i built and i'am tired of f-----g with it sorry for the harrsh language but i've had it it's a starter and flywheel problem that is within the block but any way's i have a 1974 472 that i put in a 1978 chevy 1 ton and as we all knowthe mounts between 1978 and 1972 are different and would like to see what you have come up with thanks very much appreciated
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear
1bad chevy is offline   Reply With Quote
Old 08-13-2007, 01:36 PM   #2
Jayss109
Active Member
Jayss109's Avatar
Re: 500-472 caddy installation question?
There are some photos on my webpage below. Only problem with the pictures is this..... The are on BACKWARDS in the photos... ie, left to right switch, then filp them over... But you get the idea.
Throw it under the hood, center it up, and have at it.
J
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 08-13-2007, 03:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here is a 10 page thread in the engine and drivetrain section of this board;
http://67-72chevytrucks.com/vboard/s...ad.php?t=20020
Here is a half ass site I threw together showing the ins and outs of my install.;
http://www.geocities.com/caddyoneton/
You've done it before, you know whats needed. Fuel pump on wrong side, Dist wire needs lengthened, New exhaust pipes...
Specific to these trucks;
Had to dimple the dvr side of the cab, down low by the clutch hole for head/valve cover room. You you are OK depending on a mechanical fan to cool it, you can skip this... or if you have the means to cut and weld, you can bubble that part of the firewall.
Engine stands... I took the 73 - 87 2 wheel drive style... like you used before, put a hole in the center, then used a plazma cutter to trim off the front lower corner, and installed them up forward where they were needed. I also had to 'uncurl' the passenger side framerail where there is clearance for the big block chevy fuel pump... I just used a hammer, it coulda been done a bit nicer though.
You'll want to get rid of those gears... TRUST ME (look in my siggy).
Old 08-13-2007, 07:41 PM   #4
1bad chevy
1bad chevy's Avatar
the only thing that really s----ks is i dont have any off the 73-87 froame mounts well to the junk yard i go thanks guys let ya know how i make out and as far as changing the gears we'll see i'm lookin to have a little fun with a local load mouth
Old 08-13-2007, 10:12 PM   #5
jott_06
Camaro Club
jott_06's Avatar
The problem with your 350 sounds just like the problem i had with a 350 and a 307 in the same car. I just kept buying starters and flexplates and tried shimming the starter different ways and it kept tearing up starters and flexplates. I eventually used up my limited lifetime warranty on starters at advanced auto within no time and my stepdad asked to look at the screen to see the description for the starter they kept giving me and it said metric. So we found out there are metric and standard starters. i put a standard starter on it and its fine
jott_06 is offline   Reply With Quote
Old 08-14-2007, 07:12 AM   #6
1bad chevy
1bad chevy's Avatar
????? my problem is i can't shim it close enough i believe the block was linebored and tha t put the tolerances out of wack i may be wrong
Old 08-14-2007, 08:58 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
have a machine shop trim the nose cone of the starter.
68C15 is offline   Reply With Quote
Old 08-19-2007, 09:30 AM   #8
1bad chevy
1bad chevy's Avatar
to late to turn back now went with my own design for mounts didn't want to modify my frame incase i ever wanted to go back to a chevy bbc that is here's what i got it's all mounted now i have to wire it and plumb up the fuel etc. in other words it's in there.here is pic's of it in and the mounts used factory truck frame mounts and factory caddy mount'sand connected them with some heavy plate steel then pulled out the welder and presto
Old 08-19-2007, 09:33 AM   #9
1bad chevy
1bad chevy's Avatar
and some more. next step paint her up pretty
Old 08-19-2007, 09:39 AM   #10
1bad chevy
1bad chevy's Avatar
this was all done without cutting or pounding anything other than making the mounts oil filter clears,didn't touch firewall,moved trans crossmember forward to the bolt holes all the way forward,drivshaft perfect fit I CAN,T WAIT TO DRIVE IT
Old 08-19-2007, 11:32 AM   #11
suville
suville's Avatar
Unless Im missing sumthin looks like its a solid mount, not sure if that would be the best for street, lots of vibration and noise transfer. Also you could encounter fatigue breaks having the mounting points at the leverage theyre at, remember these engines are torque pigs! You should be able to come up with the 73-up style frame mounts and it wont change engine location then use 425 rear wheel drive caddy engine brackets makes a factory looking swap, using GM clamshell mounts. Cant post pics here but if anyone is interested Ill be happy to email pics of my swap. And yur gonna luv the torque. My 69 burb is turning about 1250 RPM at 35 MPH With yur foot in it shifts into 3rd (th400 with shift kit)at about 4200 and is leaving the 80 MPH neighborhood very quickly! Ssswwwweeeetttt!
suville is offline   Reply With Quote
Old 08-24-2007, 07:33 AM   #12
1bad chevy
1bad chevy's Avatar
well it's in ther run's sweet. there no vibration, no noise. and it fit's sweet no oil filter issue's no fan issue's, as i said before the only modification down was for the motor mounts.now to all that have done this what cfm carb are you running i believe the 750 edelbrock is starving it for fuel here's some pic's. oh yea changed the grill and fender's to a 69 nose do you like it ? one other question i got this out of another truck someone put a rear sump pan and pickup tube on her from a 425 is there a check valve or something in there to keep the pump primed having an issue with cold start's no oil pressure for first 5 sec's or so after that it's up to 40-50 pounds and stay's good the of the time any idea's yes it's a new oil pump
