![]() Join Date: Oct 2006
El Cheepo Rear end ??
I got a rear end off of my brother in laws 67. (He converted to disc on all 4 corners.) I had orderd a rear end conversion kit from CPP. Well the kit they sell will not work for my 60 , so back it goes.
The "new" rear end has a panhard( trackbar) mount on the pumkin,were as mine was atached on the axle part Ok my question is should I use a trac bar from a 67? How hard would it be to make one? I still have to install new axle seats and set the pinion angle, ( I'll farm that out to to Chief)
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Jun 2002
Re: El Cheepo Rear end ??
Use the track bar from the 67, piece of cake! Or, if you are a glutton for punishment, use the 66 track bar, cut the bracket off of the old axle and weld it to the 67 (lots of work for the same effect...)
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
I put a chevy 10 bolt in my 60 panel and made my own tracbar with high quality steel and high quality rose joints so its adjustable. I used the original frame mount and fabricated a bracket to weld on the shock brackets. The longer the tracbar the less sideway movement your axle will have during suspension movement. It wasn't too difficult to make. Steve.
#4 | |
Hollister, CA.
![]() Join Date: Sep 2006
It's not even a big Sal....I'll hook it up no problem man !!
I'll fab everything we need for the track bar !! John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Right on !!! Thanks John.
Why don't I have a buddy with a fab shop???
Rg
Hollister, CA.
I'll be your buddy...come on over
![]() John
well i can fab up brackets and **** but not like yall. lol i eaither get scrap metal and bend it with pliers or whatever will work or use JB weld or silicon. but it would be nice to have a friend at a fab shop.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Hey, I appreciate it, but the drive would kill me! I do miss the Cali weather...
It's hot as he11 here! Rg
