Old 08-13-2007, 09:06 PM   #1
chevymotocross
chevymotocross's Avatar
Fuel Tank question
I got an 87 swb silverado 2wd with the dual tanks. I've been filling up the driver's side tank and decided to try the passenger side. Well I put about $30 worth of fuel in and it all leaked out at a parking lot . I removed the plastic shield and that tank is pretty shot. Are these tanks 16 or the 20 gal version? I believe they are the smaller 16. Also, not the straps, but the 2 big metal brackets where the shield mounts to are rotted. I can't find replacements , any recommendations? Also, does the 305 tbi have a mechanical fuel pump or is there an electrical in-tank pump, in both tanks? How hard is it to replace the passenger side tank?
chevymotocross is offline   Reply With Quote
Old 08-13-2007, 09:17 PM   #2
OJOE
Crew Cut
OJOE's Avatar
Re: Fuel Tank question
yes the short beds have the small tanks and the 87 does have elec pump in tank. not to hard to replace. the plastic sheld holds dirt and is bad to rust out tank so be careful w/used tank. good luck
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 08-13-2007, 09:26 PM   #3
chevymotocross
Yup, I noticed all the rusted flakes that were sandwiched between the shield and bottom of the tank.... like 10 lbs worth! So both tanks have a pump? I guess that's a good thing since my family and friends seems to be having bad fuel pump luck lately. What's nice is if one pump goes bad, you can switch it to the next and get home if you have fuel in both.
Old 08-13-2007, 10:38 PM   #4
ont_guy_38
ont_guy_38's Avatar
i come across these the other day while browsing around as I need some too http://cgi.ebay.ca/GAS-FUEL-TANK-STR...QQcmdZViewItem
ont_guy_38 is offline   Reply With Quote
Old 08-14-2007, 10:10 AM   #5
Jim85IROC
Jim85IROC's Avatar
A couple of the brackets on my truck were rotted. I chose to buy a used set because people told me that the reproduction brackets don't have the nuts welded on to them, and I didn't want to have to screw with a nut on the backside in the event that I ever chose to remove the tanks without removing the bed.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 08-14-2007, 11:18 AM   #6
Roper
I didnt even think you cant buy new repro brackets, only the straps?
Anyway I bought new straps and rebuilt my brackets. Then I was at a junkyard looking for other parts and I happened across a scraped gas tank that had like new brackets and straps on it. Haha I could have bought it for $10. Would have been a lot cheaper and easier than rebuilding my old ones.
Roper is offline   Reply With Quote
Old 08-14-2007, 01:05 PM   #7
chevymotocross
This is what I was referring to. I don't think these are the same brackets as the ones on that ebay auction.
I think I have to remove these anyways to drop the tank.... correct? I figured I would get replacements since as you can see they are pretty shot.
Old 08-14-2007, 01:12 PM   #8
Jim85IROC
Jim85IROC's Avatar
They look like the right parts, but it's a little deceptive because the one on the right is not oriented properly.
454
TH400
My Sounddomain Page
Old 08-14-2007, 01:36 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You will want to remove as much gas as you can from the tank before dropping it. The brackets on Ebay appear to be correct.
When dropping it, remember the supply, return lines are hooked to the switch valve, You might want to remove them (after marking them) along with the vent line. remove the filler neck/vent also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-14-2007, 06:55 PM   #10
Poopski
Poopski's Avatar
I bought new brackets and straps from a GM dealership for about 80 bucks a piece, brand new. I bought some nuts and had them welded on for me. Trust me removal is a lot easier than installation, I'm still trying to get that damn thing back under there.
1985 Chevrolet C10 305 2wd LOOOOONG Bed
Broke as a joke and funny as a funeral
Poopski is offline   Reply With Quote
Old 08-14-2007, 09:43 PM   #11
OJOE
Crew Cut
OJOE's Avatar
i find it a lot easer to just take the bed off and get it out of the way. this way you can get to all the fuel lines and the tanks.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 08-15-2007, 09:20 AM   #12
Jim85IROC
Jim85IROC's Avatar
That's what I'm doing, but even that has its own host of problems. 4 of my 8 bed bolts spun, so now I've got to screw with getting them out.
454
TH400
My Sounddomain Page
Old 08-16-2007, 12:07 AM   #13
chevymotocross
Thanks for the replies guys. I think I am going to hold off a bit on this replacement. My driver side tank has been fine. I thought about, I'm not doing very large trips. Basically I would be going through all the headache and cost to...... just put more money in the tank. I can better spend that money, at least for now, somewhere else. But I will save the useful information when I feel the need to replace it. Thanks!
Old 08-16-2007, 09:49 AM   #14
Jim85IROC
Jim85IROC's Avatar
the longer you wait the worse it'll be. That's more time for bolts to rust.
454
TH400
My Sounddomain Page
Old 08-17-2007, 07:28 PM   #15
chevymotocross
I actually took another look at the tank today. Actually, this tank is still very usable. The brackets, where the big plastic shield mounts to, does not look very good, but I think I can work with it. Now the tank itself looks pretty decent and I can see why and where it was leaking from. There are 2 very small pinholes. The rest of the bottom half of the tank I gave a light sanding. I think if I fill those pinholes, and seal the bottom half of the tank with something such as por15 or even rustoleum, it would last quite awhile. The surface of the pinholes are clean. I know jb weld will bond, but will the fuel eventually eat thru jb weld? If so, is there another chemical I can use to fill without fuel eating through? Also, is sealing the bottom half with por15 or something similar a wise thing to do? Those pics make the tank seem worse than it really is, it's all just minor surface rust.
Old 08-17-2007, 11:15 PM   #16
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
In 1990 I backed over a tree stump in my little Chevy LUV 4X4, puncturing the bottom of the tank. Since I was 100 miles from the backend of nowhere and on transient leave at the time, changing the tank was not possible. So I splooged some LB Weld on it as a temporary fix.
In 1997 when I finally sold the truck (almost 50,000 miles later) the tank was one of the only original things left on the truck and still going strong.
So yes, JB Weld will repair a small fracture in a gas tank quite successfully. Mine was about 1/16" wide and about 4" long to give you an idea.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 08-18-2007, 08:39 PM   #17
chevymotocross
Wow, talk about bad luck. My truck was parked in my garage during the night, since today I wanted to jb-weld the passenger tank. Well I walk in my garage and I smell fuel. I look under the truck, and now my driver's side is leaking a bit! It's not repetitious and bad like the pass. side was, but it is leaking and only a matter of time before it gets worse. Unlike the passenger side, which appears fixable, the driver's side developed a leak under one of the straps. It needs to be replaced for sure. So right now, the jb-weld is drying on the passenger side pinholes. I'm going to order a 16 gallon tank to replace the driver's side. Some questions....The pump works, but since I am going to replace the tank, should the pump be replaced? Driver/passenger tanks are the same? I notice pepboy's computer does not distinguish between passenger and driver, just differences in capacity size (16 gallon and up). Talk about horrible luck.
Old 08-20-2007, 11:43 AM   #18
rfmaster
rfmaster's Avatar
Tanks are the same, but fuel pickups are right - left specific.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
