Active Member
is it worth buying a Used 454 Big block motor
I found a 454 Motor dont really know the history of it .
# 10069286 i belive its a 4 bolt mark IV Short Deck year 90-91 think he wants 800 for the motor and says he has the motor mount bracket that will cost me extra. its almost complete minus the Carb. would this be worth buying or should i play it safe and buy a crate motor. BAGGERSOCAL |
Re: is it worth buying a Used 454 Big block motor
i sold one for $500 complete minus dizzy and carb with a th400 and it wasnt to easy to get rid of, it was an 88 model. hope this helps
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
Active Member
$800 is a little stout for a rebuilder if you do not know what the internals look like. You need to look at the head codes, if they are "peanut port" heads they are not very good for any high rpm use or resale value.
If you can hear the motor run and feel comfy that you do not have any big issues 800 is an OK price
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Active Member
the motor isnt installed its at a Salvage yard.
i will check the Heads next time i stop by. |
if it is all stock it doesn't make the power it should the older 454's made more power cause gas was cheaper in the 90's people started caring about gas mileage, so if you are looking for power your only gonna want the block, you might be able to use other parts to but different heads would do alot of good
Junior Member
I have a 454 in my 92 GMC K-3500 and it is a dog compared to the older ones.
My son has an older model 454 in his '70 C-10 and it seems to have a lot more power. Danny - Southeast Missouri |
$200-$300 core value
Do the Dew!
I recently picked up a car hauler, 1974 GMC 1-ton modified to haul cars, then modified to haul sheds for a local lumber yard (where I work) It had less than 5000 miles on a rebuilt 454, less than 6500 miles on the rebuilt TH400 tranny, the whole truck was picked up for,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,$800.00! (I just got lucky is all) It couldn't pass the State Vehicle Inspection.
I think $800's just a little high, too.
A friend recently found a magnafluxed and boreable 454 block, turned crank, pistons and rods, all the sheet metal, stock manifolds, balancer and flexplate, and 2 sets of heads (781's and Peanut ports) plus all the nuts bolts, pushrods, etc. for $750. The deals are out there. Keep looking. Good luck.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#10 | |
It's the air up here
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
![]() Join Date: Nov 2006
They Quit Making Good Bbc Engines After 1973. After That They Were All In The Cost Cutting Years And Smog Engines. Best Bet Is To Find A Early Engine, There Out There 4 Sure.
Bob
I BELIEVE IN JOHN 3:16 |
