Old 08-13-2007, 11:40 PM   #1
cochino12
It followed me home?
cochino12's Avatar
shaved handles, where did you mount your solenoid?
When I shaved the handles in my 85 I used a regular door lock actuator and mounted it under the latch and it worked great. I cant seem to get it to work the same on my 77 but I found a shaved handle kit with a couple of "pull" solenoind but cant figure out where to mount the solenoind and pulley/wheel. Anybody have pics of where and how they mounted theirs? thanks
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-14-2007, 12:09 AM   #2
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: shaved handles, where did you mount your solenoid?
I have a 40lb kit that Im waiting to install. Ive found some internet "how to" by searching google. I have a 79 I think your doors are the same. I just have no clue on where to install the door popper.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 08-14-2007, 12:14 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
I usually mount the solenoid on a bracket in the opening just above where the arm rest mounts. run a cable back to the latch and attach it where the rod for the inner handle mounts. remove the rod and replace it with another cable and attach to the inner handle.. ( so that the solenoid does not have to pull against the handle) use high quality cable and clamps to prevent failure.
I have found this to be the most reliable setup for me. Sorry I dont have pics.
bagged74 is offline   Reply With Quote
Old 08-14-2007, 12:26 AM   #4
cochino12
cochino12's Avatar
damn I'm dumb ha ha, didnt think about taking the rod for the inner handle out and using a cable. I tried mounting it there but it hit the rod. Thanks that'll work great.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-14-2007, 08:53 PM   #5
cochino12
cochino12's Avatar
Got them and the alarm installed and working great. I've always just used a brake spring to help push the door open but they dont really work too well. In my last truck I bought an expensive spring but it kept the door from lining up right, what have you guys used to help push the door open and where did you put it? Thanks again
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-15-2007, 01:17 AM   #6
knightlife
Dark Heart Motorsports
knightlife's Avatar
hope that helps
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 08-15-2007, 01:27 AM   #7
bagged74
its just $$$$$
bagged74's Avatar
Thats exactly what I was talking about. /\/\/\/\/\/\/\/\
works best if you replace the rod with a cable too!
Old 08-15-2007, 01:27 AM   #8
cochino12
cochino12's Avatar
Originally Posted by knightlife View Post
I hope that helps
Thanks, I got the actuators in but now I'm not sure what I'm gonna do about poppers if I decide to use any at all.
bagged74, thanks for the tip I just got done replacing the rod a couple hours ago. It worked great
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-15-2007, 02:39 AM   #9
knightlife
knightlife's Avatar
I dont have any pics of my poppers...cuz honestly, Im playing grabass with the rollpan atm should have that on tommorrow then back to shaved doors.
you can thank a buddy of mine from detouring me tho, lil buttsniffer yellin how ugly my bumper was lol.
anyway...for the poppers, its prolly best if you mount them where the door hang is, cuz they are only going to pop about 2 inches, so if at the back, will give you guesstimately 5 inches to play door grabber with.
Im keeping my pull cable in there until I can take and wire everything up, gotta love distractions! oh yea, Im doing all of mine in a dorm parking lot here on base LOL.
