Old 08-14-2007, 12:51 AM   #1
my70chevyc10
my70chevyc10's Avatar
smoke
Help..... i have grayish white smoke coming from exhaust and i dont know what from. Oil is full and water is full please help
my70chevyc10 is offline   Reply With Quote
Old 08-14-2007, 12:56 AM   #2
chipflyer
chipflyer's Avatar
Re: smoke
If its an auto trans and it is smoking badly it is probably the transmission modulator valve sucking trans fluid up the vacuum line and burning it. Disconnect the vacuum line and see if it stops smoking.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 08-14-2007, 01:14 AM   #3
my70chevyc10
Re: smoke
its a 350 with a 3 on the tree
Old 08-14-2007, 10:48 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: smoke
Back in the day, we were told that bluish smoke was oil. White smoke was water and that was it. If it smoked on startup but cleared up after a few moments, it was probably valve stems causing the oil to settle on top of the pistons. Using a set of Studebaker umbrella seals on the stems was the cure that we were given. Coolant that found its way into the combustion process would cause white smoke, that was actually steam. Cracked blocks, leaking head gaskets, cracked heads were all possible sources. Grey smoke....fuel issues? Does the smoke have a specific odor? Usually, in my experience, fuel burning issues caused my truck exhaust to burn my eyes. Running really rich. Changed carbs and cured that problem. My Lexus has a brief puff of smoke on startup, but I'm not worried about that. My truck has blowby and the only cure for that is gonna cost me....rebuild or replace.
Member Nr. 2770
Old 08-14-2007, 10:31 PM   #5
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: smoke
I had a similar situation little over a year ago with my 72 C2500. White smoke out of the left bank. Pulled the spark plugs and a trickle of liquid came out #7 hole. Tasted it and yup, antifreeze. Had to be a head gasket leak.The coolant in the radiator had not dropped noticably. It doesnt take much to create a lot of smoke. I had built the motor in 1986, and that damm head gasket only made it 20 years! Oh well, replaced them and no more smoke.
Any way thats my guess---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 08-14-2007, 10:56 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: smoke
If the engine is otherwise in good shape and you're suddenly burning a whitish smoke. It's more than like condensation of some sort. Either water from the radiator or moisture accumulating in the exhaust.
Put your hand by the exhaust (careful not to burn yourself of course) and let the exhaust condense in you hand. You can usually detect the odor of anitfreeze, xmission fluid or other.
I also agree as was mentioned that oil burns a bluish color, gas a gray, dark gray or black and water whitish color.
68gmsee is offline   Reply With Quote
