Blazer tank and fuel injection
I originally wasn't going to run a blazer tank because I thought they hung down too low, but after seeing one installed in person I don't think it will be a problem.
My next concern is, is it going to work with a fuel injected LS1? Don't most fuel injection tanks have baffles in them? I was also looking at fuel cells @ Summit. They have some with foam in them....will this work with fuel injection. Right now with my 72, I'm running the stock tank with fuel injection, and as long as I don't let it run too dry (<1/8 tank) I don't have any isssues. |
Old member
Re: Blazer tank and fuel injection
I would make sure it has the baffels inside it no matter what tank it is. I ran the foam in my tank for awhile with no trouble. I bought the foam at a race car shop. Make sure you run a pre filter on the inside of the tank though. I had mine at first without the baffels and it would let the sending unit go all over the place when I was driving it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Justified!
Do ya'll have in-tank fuel pumps, or in-line? Just curious......I am trying to decide which to get for my set-up...
Thanks Chad
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() Last edited by 64GMCHorsepower; 08-14-2007 at 12:02 PM. |
right now I have an inline pump and filter.
Take a look at this setup:
http://www.thedetailzone.com/Tanks%2...%20Install.htm
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Justified!
I was looking at the same thing earlier...They run around $ 220.....
But they are adjustable, and you can fit them in most tanks......
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
