Right Turn Signal Dash Light
1971
Turned on my headlights this morning and the right turn signal indicator light stays on. Signal works fine, the light just stays on, (only when the lights are on?) Any ideas? Last edited by aventur1; 08-14-2007 at 11:24 AM. |
![]() Join Date: Nov 2004
Re: Right Turn Signal Dash Light
Could be a ground issue. I redid my dash about a month ago and noticed that all of the connections where the light bulb units screw into the back circuit board were "dirty" and "corroded" looking. I used some metal polisher stuff I had and cleaned up all the connections until they were shiney again. I also did the same thing where the plug goes into the back of the gauges.
My turnsignals used to do the same thing when I turned the lights on, but now they work properly....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-14-2007 at 12:13 PM. |
Dave's not here, man
Both of mine do that. I haven't had time to look at it yet, but I think it's most likely a grounding problem. I'd check that and also do as
67ChevyRedneck said and check the circuit board for corrosion.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Thanks, I'll rip and tear into this weekend!!!
its all about the +6 inches
the light is supposed to do that when there is a bulb out. If your bulbs are good front and back, then pull the lights out of there sockets, inspect for corrosion and/or nasty grease, clean as needed... if it still does it, then take a good look at the grounds.
^Really? Never knew that! I replaced a couple blown bulbs when I redid mine, maybe that's what actually fixed it!
![]() Man, I learn something new everyday ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-14-2007 at 07:14 PM. |
To clean the contact surface on the printed circuit use a typewriter eraser. Don't use a regular pencil eraser they leave a residue on the metal this also works for the plug pins on the dash wiring harness.
#8 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
![]() Quote:
wow, thanks everyone, I did'nt know about the bulbs either would make the light stay on. All signals work, I'll start there before I go to the dash, Thanks again, good job !!!
side markers won't do it, they don't draw enough of a load to make a difference.
Old thread, but I had a different solution to this problem on my '70. Turns out there was corrosion in the crimp where the bulb socket attaches to the reflector/housing. A quick pop with a punch and the ground was restored. Problem fixed!
_____________________ Lou Axt, Jr. 1969 C10 Longbed 292 inline 6 Offy, Holley, true dual exhaust tows a 1966 Airstream Tradewind |
