Tie-down hook suggestions?
My 87 swb has a nice pace-edwards roll bed cover. I really like it but for me to load my bike in the bed, I have to actually remove the front plastic cover of the unit, and put those cheesy stake tie down points in the stake holes since the plastic cover blocks half of the stake hole. I posted a pic so you can understand what I mean. I have spent some time just looking in the bed, seeing where I can maybe mount or possibly weld a strong mounting point but I am stumped! Any suggestions?
Here is what the cover looks like: ![]() Here is the plastic cover piece that is blocking access to the stake hole for an anchor point drop in.
The Crazy Machanic
Re: Tie-down hook suggestions?
if you get the atchment for the bed holes and grind a bit og of the loop it should fit around that pastic part.
like this but they are allways up ![]() there is also this option ![]() id get me some of these and customize it a bit so tha the flush part is under the plastic and the other is in the air. Like welding a nother piece to it so it woill be fully closed at all times ![]() And then there is this ![]() And my last idea intell i think of more http://www.extang.com/docs/cargocleats.html
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one
you could mount the tie downs to the inside of the bed below the stack pockets, on the stack pocket "tunnel". They would always be there when you needed, but out of side when bed cover on and would not interfere with operation of said bed cover. Or you could just be a bike mount (holds front fork with tire removed) and mouht it to the bottom of the bed.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 08-14-2007 at 08:02 PM. |
| Bookmarks |
