Old 08-14-2007, 03:02 PM   #1
Batman
4x4 Front wheel bearing adjustment
This is on a K1500. I really need to get a better service manual for this truck, all I have is the haynes one and I don't know how much to trust it. Does anyone know if the adustment procedure is correct?
Tighten to 60ft-lb while spinning tire
Back off 1/2 turn
Tighten to 30-35ft-lb while spinning tire
Back off 3/8 turn
Tighten until lockwasher engages
Tighten locknut to 80-125ft-lb
Seems reasonable to seat the bearings in and such, does anyone have a better procedure?
1972 GMC K1500 350 V-eight TH350 4x4.
Batman is offline   Reply With Quote
Old 08-14-2007, 05:31 PM   #2
ckhd
ckhd's Avatar
Re: 4x4 Front wheel bearing adjustment
I'm at work and don't have the book in front of me, but the factory service manuals are very similar, if not the same.
By the way, I have tried 'other' methods, like the 'tighten it unitl it stops spinning, then back of X amount' and it never works right. Using a torque wrench is the ONLY way to properly adjust the bearings.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-15-2007, 11:43 AM   #3
72swbcamo
Active Member
Here are the instructions from the SKF, Torque Specification Guide, Front and Rear Axel Nut Torque Specifications for FWD and RWD Vehicles.
1970 - 72 K10, K1500, 4WD Pickup.
Thighen adjusting nut to 50 ft-lbs / 68 Nm while turning hub. Back off and retighten to 35 ft-lbs / 47 Nm. back off 1/4 max. Holes in washer must align with tang in slot in spindle. Tighten locknut to 50 ft-lbs / 68 Nm. End play should be .001 0.010".
I used this procedure for my front end. I am not on the road yet but everything seened OK.
This manual is downloadable from the enternet. I think I Googled: SKF Torque specs to find it. Good luck.
72swbcamo is offline   Reply With Quote
Old 08-15-2007, 02:23 PM   #4
Batman
Cool...thanks for the tip on the torque manual. The only difference between that and the procedure I have is the locknut torque....That probably doesn't matter much since it just has to hold the adjust nut in place, and the washer won't let it spin anyway.
Thanks!
Old 08-15-2007, 02:25 PM   #5
Burt4x4
Burt4x4's Avatar
Yup!
I have done this for years and years
First nut needs to get tightend to 50ftlbs while turning the rotor, I like to go slow and spin the wheel to make sure the bearing seats properly.I even take a dead blow and lightly pound on it while turning just as an added precaution. Once I get at least 50ftlbs of torque I back it off then re-torque to 35ftlbs. Next is to slide in the washer that has the holes, one hole slides over the tit on the nut. Never tighten the nut to fit the tit into a hole. Take note of were the nearest hole is counter clockwise and turn the nut to the nearest hole.
The second nut gets torqued to 50ftlbs.
At this point I spin and check for up/down wobble..there should be no wobble and the spin should feel free not stiff.
Yer done
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-19-2007, 11:11 AM   #6
Batman
Just got done with this job yesterday. I have to get a bearing packer before I do this again, I forgot what a mess it is packing bearings. The torque wrench was definitely the way to go. Thanks!
