Old 08-14-2007, 03:13 PM   #1
Randy65
Help!!!!
I have just installed a 350 with a 3 speed automatic transmission in my 65 fleetside. I need suggestions on how to connect the throttle. When you push in the gas peddle the throttle rod only travels a ½ to ¾ of an inch. The throttle bracket on my new motor’s carburetor travels way more than an inch. Any suggestions?
Randy65 is offline   Reply With Quote
Old 08-14-2007, 04:38 PM   #2
Ogilthorpe
Ogilthorpe's Avatar
Re: Help!!!!
I did the same conversion on my 66 (but with a 700r4) - I ended up going back and forth with different pedals, cables, linakges, etc. Finally ended up with the stock pedal/arm and it works great. I bent a 1/4" rod to connect to the carb. I'll snap a picture when I get home and post it for you.
Ogilthorpe is offline   Reply With Quote
Old 08-14-2007, 04:47 PM   #3
3speed 6cyl
3speed 6cyl's Avatar
Re: Help!!!!
an original carb. throttle in 1960's also needs more pull distance than the acual level creates when stepping on the gas. it creates more pull distance from 2nd lever closer to the carb. You can create this and secure it close to the carb. on your 350. To explain or understand this level take a pencil/pen and hold it <1 inch up w/ your index and thumb. Move the short end with your other hand that distance your 1 rst lever gas pendal allows. The opposite long end that you weren't touching now moves 3-4X the distance that the 1rst lever close to the fireawall moves. Go to pick n' pull/auto wrecker and you'll probable find plenty levers that will work for your 350 carb. GOOD LUCK you'll work it out.
3speed 6cyl is offline   Reply With Quote
Old 08-14-2007, 04:56 PM   #4
Randy65
Re: Help!!!!
Thanks for the input and I will look forward to seeing your pictures
Old 08-14-2007, 07:19 PM   #5
NF65Fleetside
NF65Fleetside's Avatar
Re: Help!!!!
what 3spd said, Ill try and take fotos for you tonight. Im running a 4bbl holley, Ill take pics of where I attached my throttle at. Also will add pics of my Lokar big stick shifter too.
NF65Fleetside is offline   Reply With Quote
Old 08-14-2007, 08:52 PM   #6
Randy65
Re: Help!!!!
Thanks NF65Fleetside. Any pictures will be really helpfull.
Old 08-14-2007, 08:56 PM   #7
Ogilthorpe
Ogilthorpe's Avatar
Re: Help!!!!
Here's some pics, hope they help. Basically a 1/4" rod (bent to fit) threaded one end to secure to pedal. I used an edelbrock adapter to hook it to the carb and to have some adjustment on length, but if you get the length right, you could just bend another 90 in the rod and attach directly to the carb. I did end up using a mounting hole close to the center of the pivot shaft on the carb like 3speed said.
Old 08-14-2007, 09:00 PM   #8
Randy65
Re: Help!!!!
Thanks Ogilthorpe, the pictures are great!!!!!
