Old 08-15-2007, 01:07 PM   #1
sameyrasmea72
sameyrasmea72's Avatar
Rearend ?
Will a posi-unit and all the guts out of a 1981 truck 12-bolt swap with a 12-bolt 1972 rearend? I don't think the posi if a factory unit, but my cousin spent a lot of money on this rearend and now the truck is parked and is going to let me swap if possible. The 81' is a 373 and the 72' is a 307 if that makes any difference.......Thanks Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-15-2007, 01:10 PM   #2
Scott68-93-97
Scott68-93-97's Avatar
Re: Rearend ?
That will work, if you were just swapping gears you might have a problem but since you swapping the carrier also it will work.
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
