Old 08-15-2007, 04:24 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
tilt column questions
Hey guys, question for the 73 - 87 experts...
Are the tilt columns worth much to you guys?
Did they chainge at all in the 14 years they run this body style?
If so, when was the break, and what was the chainge? (I'd guess wiper switch)
Any added info I forgot to ask would be cool.
I see quite a few of these tilts in the local yards, and plenty of them are even tight... so i wanted to see if there was any money to be made on this.
Old 08-15-2007, 05:54 PM   #2
Jonboy
Slots go on anything!
Re: tilt column questions
They are basically the same, but had two major changes. In 77 or 78, the main plug on the side was changed, but is easy to swap. If you are going to grab one out of a junkyard, just cut the wiring harness after the main long plug on the side of the column. The wipers went to the turn signal stalk in 84. Also, if you find a floor shift tilt column, those are more desirable to some folks looking to convert to floor shift.
Old 08-15-2007, 06:09 PM   #3
Eyegore
What Hump?
Eyegore's Avatar
I'd just pull some out and put them on e*ay or craigslist and see what kind of action you get. One thing though, i would not cut the harness, remove them at their connections, I say this because if i were a buyer i'd rather plug it in instead of splicing wires. Also get a variety w/ and w/o cruise control and I think the headlights on the column are more desired than the floor one.
So there's my 2 cents, hope it helps.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-15-2007, 06:11 PM   #4
Jonboy
I meant cut the harness of the donor truck, to get extra wiring. Don't cut teh wiring going into the column.
Old 08-15-2007, 06:20 PM   #5
Longhorn Man
all good info.
Ball park, what are they worth... am i lookin at 100 bucks, or would you guys only wanna pay like 50 - 75?
Old 08-15-2007, 06:59 PM   #6
Eyegore
What Hump?
Eyegore's Avatar
I've seen here on c/l for 125
Lil red 86 c-10
99 Sub
Old 08-15-2007, 07:00 PM   #7
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
id give 50-100 but my truck already has one and a guy gave me another so im set if i ever need another. Wish it would fit a 1970 chevelle but it would look odd not being metal.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
