Brackets and pulleys and other engine stuff
All brackets with accessories and pulleys $250.00 or priced individually below. Sold
A/C: brackets are factory 67 pieces. I believe they 67 only pieces. A/C was working when removed 01 Aug. Brackets and compressor $150.00. Sold Alt: brackets are factory 67 pieces. worked when removed 01 Aug. Brackets with altenator $40.00 Sold P/S: brackets are from early 70s truck that were purchased from another board member. SEE NOTE BELOW FOR MORE INFO. Pump is about one year old from O'Rieleys. Worked when removed 01 Aug. Brackets with pump $50.00 Sold Note: The factory AC brackets make the belt run on the forward most groove. The factory alt brackets make the belt run on the rear groove. This is contridictory to later styles so the P/S bracket was milled down so the belt would line up with the middle groove. LOOK AT THE PICTURES. Pulleys: Factory three groove fan pulley and three groove crank pulley. $50.00 for the set. Sold Trans: Alluminum case powerglide that is worn out. Always slow into reverse and slow into drive when hot. I promise it leaks. Worked when removed 01 Aug. Trans with convertor $150.00 Manifolds. Rams horn. Not cracked that I can see or hear. $40.00 each or $75.00 for both Prices do not include shipping. I live in Highland Village Texas (20 miles north of Dallas) zip code 75077. estimate your own shipping. Tell me how you want it shipped and that is who I will use. Everything seen in the pictures is for sale so If you want something that is not priced let me know and I will price it. Will trade for nice 67-68 grill, nice tilt column, 67-70 outside mirrors or possible other items.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug Last edited by 2500HD; 08-21-2007 at 08:24 PM. |
![]() Join Date: Oct 2005
Re: Brackets and pulleys and other engine stuff
I will take everything on the front of motor. brackets,pulleys,compressor,bolts
Junior Member
I would like to jump in line .
I would like the a/c compresser and all bracket with bolts . but would need shipping cost zip 93309 calif. Thanks Roger |
Junior Member
Also i have a nice 68 chevrolet truck grill ... can take pictures and send if needed ... Roger
well, I was going to ask for the ac bracket, but Jeremy wants it all. How about the passenger side exhaust manifold?
jeremy -- I have found two zip codes in Prior Lake MN. PM your address and let me know how you want it shipped. I will pull everything off this evening and get it weighed so I can get shipping costs. Who do you prefer as a shipper? I like UPS for some reason but will use whoever you like. I have a paypal account but have never used it. I will try to figure it out.
68chevylwb -- 2nd in line for the A/C stuff. Still might be interested in the grill. Can you send pictures? 72GMCburban -- 3rd for the A/C stuff. passenger side manifold is not cracked that I can see or hear. $40.00 each.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug Last edited by 2500HD; 08-16-2007 at 10:58 AM. |
Everything on the front has been sold to Jeremy.
Anyone else need anything from the pictures above?
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
