GEARHEAD
Hydro assist steering questions, PTO option
I found a couple oddities in a junkyard today, and need some educating. I found a 67 GMC flatbed, 1 ton or better. It had this little funky steering set up I hadn't seen before. What I want to know is if this will work on a 4x4 by using a different mounting to the tie rod, and if it is even worth the trouble. I know guys with larger tires use a different steering system, but I don't know if this is the set up. Is this stronger than the normal power assist?
![]() ![]() Next was a PTO which was added to a manual transmission. This was on another 1 ton flatbed in the same yard. The only reason I found it was that I came across the manual for it in the glove box, looked underneath and there it was. Is it worth anything? ![]() Lastly, a truck had some newer style buckets added in. I have no interest in the seats, but I was wondering if these brackets are original bucket seat mounts. Anyone know? ![]() Thanks in advance for any info. HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
its all about the +6 inches
Re: Hydro assist steering questions, PTO option
the power steering set up is a stock 67 and late 68 piece. It COULD be an add on, but probablynot. They were better then manual, but normally just leaked and went bad. It was added to a manual steering set up. Very much like early vettes.
GEARHEAD
Any opinions on the seat brackets or PTO?
The bucket seat brackets don't look like anything truck related. I would say definetly "NO".
I don't know anything aout the PTO so I can't help there either. I hit 50% - sorry I couldn't do better - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Junior Member
I have seen PTOs on larger trucks being used for such things as driving a hydraulic system for a lift bed.
Danny - Southeast Missouri |
