Old 08-15-2007, 08:57 PM   #1
fastbagged68
fastbagged68's Avatar
Is a LWB frame the same as a Suburban/Wagon
I have a 63 burban (the one in my avatar). Is the frame the same as a long bed? anybody know?
fastbagged68 is offline   Reply With Quote
Old 08-15-2007, 11:35 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Is a LWB frame the same as a Suburban/Wagon
I'm making a guess........but a shorty is roughly 115" and a long bed is about a foot longer....at least thats what Ive seen cut out of long beds to make em short.........so a long bed wheel base should be in the neighborhood of 127"..........nice burb.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-16-2007, 12:17 AM   #3
brawley
Easy Does It
brawley's Avatar
if the total length of the body is 199" then it uses a 115" wheelbase-short. If the total body length is 235" then its a long wheel base 127" frame. they made both.
brawley is offline   Reply With Quote
Old 08-16-2007, 02:06 AM   #4
fastbagged68
Well I measured my suburban wheel base and it measures 115". I didn't know they have a short wheel base suburban!!!! What is the difference between the two beside length?
Old 08-17-2007, 09:37 AM   #5
rodnok1
rodnok1's Avatar
The frames may be the same length, but they are not the same. Rear horns are diff from what I gather.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-17-2007, 10:09 AM   #6
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
The Suburban Frames Were All 115 Inch Wheelbases...............same As The Short Bed Pick-up Trucks....................the Long Panels And Longbed Trucks Were 127 Inch Wheelbases................i Believe The Rear Frame Horns Are Different Because A Front Bumper Will Fit On The Back Of A Burb Or Panel...........i Like The Color Of Your Burb.........hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 08-22-2007, 12:11 AM   #7
ijasond
The front bumper will fit on the rear, but the frame doesn't line up with the holes in the bumper. A fleetside rear bumper fits just fine, but then you have two places to put your license plate. I currently have 2 front bumpers on my 61 suburban, the one in the back is not too secure until I get around to making some brackets for it. the frame is the same as the swb pickup.
ijasond is offline   Reply With Quote
