Old 08-15-2007, 09:04 PM   #1
nwmod39
nwmod39's Avatar
new engine for my 86 k-20
hey guys. i found this on my local craigslist and was thinking of possibly using it in my 86 k-20 instead of selling and buying a new truck. and for the price i would think that this would be a great buy.
do you guys think that this would be a fairly straight forward swap.
http://spokane.craigslist.org/pts/394304633.html
it would be going into this
thaks steve
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 08-15-2007, 09:11 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: new engine for my 86 k-20
with or with out all the emissions and computers. casue if with out then yea the motor will go in just need a different intake for the catty corner bolts in the heads. if computerized then it a bit more work but possible.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 08-15-2007, 10:04 PM   #3
Russell
Professional Grade
Russell's Avatar
Thats a heck of a deal on an 8.1L with a transmission and transfercase! I've never seen one for less than 4000 here, for just the engine itself without any electronics etc.
Those 8.1L engines are absolute monsters, but make sure you hear it cold start to see how bad the piston slap is, and ask if there is any oil consumption. Pull the plugs and make sure they are clean with no signs of oil on them.
They are actually the easiest new engine to swap into these older trucks. They have the bosses for the old style small block engine mounts, and have a crank that is the same length as the old big blocks did, so you can put any neutral balance big block flywheel on no problem.
Basically means they bolt straight in. The only major complication that I've read about while researching the swap is running the exhaust. The big block is pretty wide, and the manifolds basically dump straight into the frame rails. Most folks overcame it by getting custom made headers that dumped the exhaust on the outside of the frame, then ran it back from there. Of course, you will need to deal with the electrical and fuel system challenges that are associated with all the gen III engine swaps, but they are easily covered these days.
You can probally get 1500 back for the transmission and transfercase too
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-15-2007, 11:25 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Thats a nice swap. I would go ahead and swap in the Allison and transfer case, not sure if the front shaft drops on the correct side though.
Pyrotechnic is offline   Reply With Quote
Old 08-16-2007, 12:47 AM   #5
Russell
Professional Grade
Russell's Avatar
The Allison is a wicked transmission (if that is what the truck has, I've seen them with either), but the t-case does drop on the wrong side. I *think* an NP241 from an 89 - 91 Suburban, K5 or Crewcab will bolt up to replace it though...
Old 08-16-2007, 08:11 PM   #6
nwmod39
nwmod39's Avatar
i have been trying to caontact him aobut this engine. the entire package is outrageous what it comes with. everything from the radiator to the trans and the gauge cluster. i think if he calls me back im going to pic k it up and do it. if not in the k-20 i always have the 80 c-10 sitting in the garage.
Old 08-16-2007, 10:12 PM   #7
Srubydo1986
The Crazy Machanic
Well if you do swap ill take the headers if you want to git rid of them. Just a thought.
newest additions
Old 08-16-2007, 10:22 PM   #8
nwmod39
nwmod39's Avatar
ill keep you informed.
Old 08-16-2007, 10:32 PM   #9
streetstar
streetstar's Avatar
That will be a sweet swap --- my DD is a Ford, but i have been driving my bro's '07 Hd for work purposes. That 6 speed auto is trick
streetstar is offline   Reply With Quote
Old 08-18-2007, 06:18 PM   #10
nwmod39
nwmod39's Avatar
recieved a retuen email form the guy. im going to go look at it tomorrow(sunday) and take it for a test drive. everything is still in the truck and he says once it is sold he will remove it from the vehicle.
