Old 08-15-2007, 09:35 PM   #1
Mechdawg
Mechdawg's Avatar
Rear Disc brake brackets
I saw someone on evilbay selling rear disc brake conversion brakets for our trucks but in his description he says they are for 5 lug axles only. So my question to you all is there a difference between the 5 lug and 6 lug axles other than the number of lugs. I always thought they were identical except the obvious.
Mechdawg is offline   Reply With Quote
Old 08-15-2007, 10:51 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Rear Disc brake brackets
67, 68, 69, and some early 70 axles were shorter. Later 70 and 71, 72 had the longer axle housing and shaft.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 08-16-2007, 01:39 AM   #3
powell72
powell72's Avatar
The biggest problem is no one has found a six lug rotor that will work, so all the brackets and piece-together-yourself kits are for five lug. There are plenty of companies that sell whole six lugs kits if you've got the $$$.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-16-2007, 05:35 PM   #4
mplex2000
mplex2000's Avatar
You could probably re-drill the 5 lug rotors to 6. They'll look like swiss cheese though and even though probably not dangerous, I don't think I'd do it myself.
mplex2000 is offline   Reply With Quote
