Old 08-16-2007, 01:59 PM   #1
NF65Fleetside
NF65Fleetside's Avatar
hot starts, starter solenoid
Aye how many of you are running starter heat shields...also anyone have the hot start issue even after using the shield?
NF65Fleetside is offline   Reply With Quote
Old 08-16-2007, 02:03 PM   #2
63 & 64 Bowties
and a few others
Re: hot starts, starter solenoid
yea, I've got the same problem with my 64. It has a 350 out of a 75 1/2 ton with black-jack headers that are only about 1/4" from the starter. I haven't tried a heat shield yet just because it probably wouldn't fit anyway in that small space.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-16-2007, 02:05 PM   #3
NF65Fleetside
yah Im thinking of maybe getting some heat retardant material and just hose clamping it to the starter itself...what you guys think about that?
Old 08-30-2007, 05:19 AM   #4
Ham-er
This is one of those "famous" chevy problems. Caused by - the facts that the chevy starter solenoid is both a solenoid bor the bedix mechanism as well as a starter relay, combined with it being so close to all that heat!! An old fix that some of us used to do was to jumper the relay teminal down at the starter and then use a ford type relay remotely mounted on the firewall. I know its not a complete fix but it does limit the heat problem only to the solenoid part of the solenoid. The copper disc inside the end of the solenoid is the relay part that gets trashed by the heat. I hope this helps!
Ham-er is offline   Reply With Quote
Old 08-30-2007, 08:21 PM   #5
rodnok1
rodnok1's Avatar
Make sure all the wires going to starter are new and heavy gauge, half the time the wires are shot(heat soaked) and the starter isn't getting any signal to start. I use a heavy 0 gauge positive wire from the battery also. Along with a high quality starter it hasn't let me down using this system.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
