I bought a stepside truck and am putting a fleetside short bed on that frame . The bed sticks up alittle higher in the back than the front , the cab to bed body lines line up at the bottom. But the bed is alittle higher starting at the wheel wells, it's about one inch higher. I want to make the bed even do I need to cut the pads off the frame and make them smaller for the bed to set level on the frame. Anyone know how I can fix this problem?
Re: bed swap stepside to fleetside
Shims work the best, Don't cut the frame mounts!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
maybe new cab mount bushings (or what ever you call them) - get it back up to original height....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
already have replaced cab mounting hardware and bushings. need help with this problem!!!
Next project: 1970 K10
Pictures would help a ton. If you can get some pics of the bed sitting on the front mounts and the rear cross sill sitting on the frame, we might be able to figure out exactly what's going on. Until then, all we can do is speculate. Let's find the problem and fix it instead of putting a band aid on it.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
its all about the +6 inches
Is the bed not sitting on the frame properly... or does the truck just sit higher in back like it's supposed to?
it sits on the frame properly and is the right height like it is supposed to be, pics really would not do any good you have to be looking at the truck to really tell.
so you are wanting to know how to lower the back of the truck... nothing wrong with your bed at all then
