72 rear end with disc conversion to wide to tuck?
I want to put a 72 5-lug rear end with a disc. brake conversion on my 65, but will it be to wide to tuck when my truck is slammed.
Re: 72 rear end with disc conversion to wide to tuck?
As Far As I Know I Have Heard That Its A Direct Bolt In They Should Not Be Any Problem
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() |
I put a 72 5 lug rearend on my 65 bolt right up and I run 20 inch rims no problem the 72 rearend is 3/4 inch longer on each side.
but will adding a disc brake setup make it even wider?
![]() Join Date: Aug 2005
whats your suspension set up for lowering? if thats your truck in your profile pic it sits pretty nice with 20's! Also any socal guys know where I can get my hands on a 67-72 setup?
