Old 08-17-2007, 12:03 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
A trip to the junk yard…..
I went to U-Pull It today and found some interesting stuff.
One that I didn’t know is what looks to be factory power steering on a ’67!
I didn’t know they offered PS back then. Is desirable for the ‘67 people or do they want something newer?
I think I found a posi and have some questions these rear ends. I was walking around several 76 -72 trucks and rotating the rear ends and found one that spins the drive line from both ends. Its on a ’70 1/2 ton 350ci. Does this mean that it may be a posi? On the others only one side would turn the driveline (mostly on the passenger side).
I also found this rear end with a cover off and thought it looked like a posi. Is it?
I’ve read threads on here that suggest that the junk yard finds may cost as much as upgrading the one I have. Is this a true statement? Or do I need one to have the correct pumpkin housing anyway?
When you guys are mentioning 12 bolt that’s the number of bolts on the ring gear right? The one in the picture is 10 bolt is it any good?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-17-2007, 01:09 AM   #2
Luvlegs
Luvlegs's Avatar
Re: A trip to the junk yard…..
that first pic appears to be steering assist setup - it is desirable to some - not very common is my understanding. There is a post from earlier in the week where a member rebuilt it and took pics all the way through. I'm sure you'll get some "pull it and I'll buy its".....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Last edited by Luvlegs; 08-17-2007 at 01:35 AM. Reason: 71swb clarified that it isn't a posi....I'm learning...
Luvlegs is offline   Reply With Quote
Old 08-17-2007, 01:20 AM   #3
71swb4x4
71swb4x4's Avatar
That's not a posi.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-17-2007, 06:37 AM   #4
Aarons72s
If I was you I would grab that ram asist power steering as some like it and they are hard to find. So probably worth grabbing it just to sell or trade to some on here. That is what I would probably do. I f I rember right you would need to grab the ram, hoses, centerlink and all brackets needed to atach the ram. As All the rest is standard to any 67 2wd truck. Just my thought.
Aarons72s is offline   Reply With Quote
Old 08-17-2007, 07:09 AM   #5
The ram-assist is a worth score,for sure.It would snatch good money on Ebay or,of course,anywhere else.The system was used on`67s and was a carry-over from the prior models.So,it`s not just`67 guys that would want it.
Old 08-17-2007, 08:08 AM   #6
Sport/Truck
Sierra Grande Club
I'm considering getting it to do just that, not sure what they will charge, what do you think it's worth? I'll post some pictures on the for sale area with a WIW title.
s/t
Old 08-17-2007, 08:10 AM   #7
Sport/Truck
Sierra Grande Club
Originally Posted by 71swb4x4 View Post
That's not a posi.
The one in the picture or the one that would turn the drive shaft from either side?
s/t
Old 08-17-2007, 09:00 AM   #8
Andy4639
Old member
Andy4639's Avatar
The power assit is worth getting, yes! The rear end isn't it's not positive traction. Ten bolts is what it takes to put the cover back on the rear end.
The junk yard may know it's worth money to, if they don't then grab it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-17-2007, 09:21 AM   #9
Sport/Truck
Sierra Grande Club
I found two rear ends, one is in the picture. The one with out the cover is the one you are committing about? When people are talking abut 12 bolts they are referring to the cover? I thought it was the bolts on the gear.
s/t
Old 08-17-2007, 09:32 AM   #10
71swb4x4
71swb4x4's Avatar
The one with the cover off is not a posi
The other could be a posi. Pull the cover and check. Don't pay much for a junkyard posi. Just because the posi works turning by hand doesn't mean it will work with the whole vehicles weight on it. Those clutches and springs can get old and worn out and quit working right.
Old 08-17-2007, 12:42 PM   #11
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
On the other rear end that you think is a posi... block or have same hold one tire, and then try to turn the other side. If both side want to turn the same direction, then it's most likely posi.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
