Old 08-17-2007, 12:35 AM   #1
AlienYouth
AlienYouth's Avatar
lowering question
so, i've heard alot of ppl talkin about just takin a torch to their springs while on the car so the weight of the car compresses it, is this just a horrible idea? i'm to cheap to lower it, but hey, if i can do it for free... so, if anyone has done this, wat's the effect on handling, ride quality, stuff like that, and how far can you lower it this way without riskin a spring breakin when ya go over a speed bump? : )
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 08-17-2007, 12:36 AM   #2
AlienYouth
AlienYouth's Avatar
Re: lowering question
crap, this should be in suspension... could someone move it? srry : (
Picturesss
71 C10 383/TH400
Old 08-17-2007, 12:45 AM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I've never actually done this, but I've heard negative things from people who have. Aside from the safety issues, it will ride like crap. I think you'd be better off cutting a coil off the fronts and coughing up a c-note for the rear lowering coils. Just my .02
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 08-17-2007, 12:46 AM   #4
AlienYouth
AlienYouth's Avatar
hmm.. i might look into it, but im saving for my motor...
Picturesss
71 C10 383/TH400
Old 08-17-2007, 01:11 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
done it many many MANY times, never had a spring break.
The ride wasn't much worse than the ones lowered with springs or flip kits.
Old 08-17-2007, 01:19 AM   #6
AlienYouth
AlienYouth's Avatar
cool, thanks longhorn, how far have you lowered yours?
Picturesss
71 C10 383/TH400
Old 08-17-2007, 11:34 AM   #7
Scott68-93-97
Scott68-93-97's Avatar
Heat the backs cut the fronts its not a good idea but it works stay toward the top of the spring it will help you retain some good ride cause the bottom to the middle wont change spring rate, it will be stiffer were you heat it, it will essentially make a home made proggressive spring on the front half coil per inch drop and 10% spring rate increase per inch, do it if you dont like the ride coils are cheap PST sells them for like 90 bucks a set
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 08-17-2007, 12:29 PM   #8
AlienYouth
AlienYouth's Avatar
thanks, how much should i drop the rear with heating it though?
Picturesss
71 C10 383/TH400
Old 08-18-2007, 11:40 PM   #9
AlienYouth
AlienYouth's Avatar
pretty please? : )
Picturesss
71 C10 383/TH400
Old 08-27-2007, 02:48 PM   #10
AlienYouth
AlienYouth's Avatar
maybe? lol, i dont wanna drop it too much and have weak springs or somethin...
Picturesss
71 C10 383/TH400
