Old 08-17-2007, 01:06 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Is a 1 ton steering box the same as a 1/2 ton?
Everything looks the same, but I can't really tell?
Anyone know for sure?
I'm up in NY for a couple days and my grandpa's old 72 1 ton is TOTALLY stripped except for a totally rotten body, blown engine and a complete unmolested powersteering set-up that only has 57K original miles on it.
Would this system fit on my 67? I know I'll have to dimple my frame. My motor also has the swp stuff on it now.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-17-2007, 01:31 PM   #2
Bob Moore
Re: Is a 1 ton steering box the same as a 1/2 ton?
Give it a try. How long to remove it - about 1/2 to 1 hour? Not positive but it should be the same. Pitman arm may or may not fit the center link. Try to get the center link if you can.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 08-17-2007, 02:05 PM   #3
I'm pretty sure they are, but you'll need the pitman arm, rag joint.
Matter of fact, isn't the 67 a one piece column? You might want to grab the intermediate shaft (or what ever it is called).
I am pretty sure the center link works interchangably for any of the 1 ton and below power or not models.
Old 08-17-2007, 03:29 PM   #4
67ChevyRedneck
I got it all off. Everything came off easy because it was covered in oil! I took the pitman arm off with it.
My truck actually has a complete '71 disk suspension under it (center link and all) and I installed the column out of the same '72 truck many years ago...
soooo, I should be good to go?
It will probably be a year or two until I can get to the install, but I have everything I need now, and you can't beat FREE
If anyone else knows why it wouldn't fit or anything else I would need, feel free to post it
Jesse James
Project "On a Dime"
Old 08-17-2007, 04:33 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
A rought search of Kragen auto parts shows the same partnumbers for a 71 1/2 and a 71 one ton. So I imagine that it should work. I would expect that the pitman arm on the one ton would be different though.... (meaning that you would need to reuse your 1/2 ton pitman)
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-17-2007, 09:52 PM   #6
67ChevyRedneck
Sounds good to me!
Thanks for looking that up!
I'll measure it when I get home, but from just looking at the power steering box it looks exactly like a 1/2 ton one, but the pitman arm appears to be a bit beefier... but I won't know for sure until I get home and can look at 'em together.
Jesse James
Project "On a Dime"
