Old 08-17-2007, 04:52 PM   #1
dan42
dan42's Avatar
5-speed in a '67
Does anyone know if a modern chevy truck 5 or 6 speed will fit without major modification in a '67 that had a 3 speed? I'm wondering specifically if the clutch linkage would match up without too much trouble.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-17-2007, 05:27 PM   #2
mvfd70
mvfd70's Avatar
Re: 5-speed in a '67
I'm going to be putting a 5 speed in my 68. I've been told that they fit up pretty good with a little modification. There are some write ups in the FAQ section on the swap to a more modern transmission. I think the tranny crossmember needs to be changed to an automatic style crossmember. Also, most modern 5 speeds use a hydraulic clutch set up. I think that if you use a T-5 you can still use your old bell housing and clutch but there might be some more modifications. Otherwise, you'll have to install a hydraulic clutch, matster cylinder and slave cylinder. That really isnt too big of a deal to install from what I've read. There are guys on here that will be able to tell you a whole lot more. Hopefully someday soon I can say form experience.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
