08-17-2007, 09:45 PM | #1 |
How to lower my 91 sub 1/2 ton
Guys, I am new to the forum and need some advice. I want to lower my 91 suburban 1/2 ton 4" in frt and 6" in back. What is the best way? I don't want air bags, but will change the spindles. What is the most complete kit out there. Which kit works the best. I only want to run a slightly bigger rim. maybe 17", I don't like the big wagon wheels.
Thanks in advance for the info. |
08-18-2007, 11:31 PM | #2 |
Re: How to lower my 91 sub 1/2 ton
1st off you the new set of spindles I have, I will take $175 plus the shipping. Then you will need some drop springs for the front. On the rear you will probably want a flip kit for it. Hope this helps.
08-19-2007, 08:57 PM | #3 |
67-72 parts collector,…
bonehead,... You will need all the drop stuff a pickup uses. (73-87) Your front rotors should be 1.25" wide,... but they do make a 1" wide version. Most front spindles are available in a 2.5" or 3" drop for your application. Then just choose the drop front spring to get you the desired drop. You will also need drop shocks front and rear. I lowered a '91 suburban years ago and used a drop leaf spring on the back (4" drop,... I think) and it worked perfectly. A flip kit on a suburban get the rear axle center section really close to the floor. A rear frame notch will also be required with the flip kit. Remember,... Make sure to order parts for the 73-87 trucks only,... because a '91 pickup is completely different. Good luck! I'll try to post a pic of my old 'burb if I can find it.
08-19-2007, 09:05 PM | #4 |
Here it is,...
08-20-2007, 10:18 PM | #5 |
Thanks, for the input. I like the pic of your suburban. I don't want mine any lower than that. I think yours looks about right to my eye.
So your was done with what combination of parts. Drop spindles 3" ? and lowered arch rear springs? Or what combination of parts exactly. What company supplied the components? Sorry for all the questions but I want to do it right the first time without spending unnecessary money. thanks, |
08-20-2007, 11:41 PM | #6 |
Belltech 3" drop spindles, 2" drop springs, and belltech nitro drop shocks front and rear. The rear leafs were from Chisolm Industries (in California) . I believe they were 4" drop. I think they are out of business now. I would check with Western chassis or DJM. Make sure you get the correct length leaf spring. I think the make a 52" and a 56" spring for these year trucks. This thing road great. I took the whole family to the Bristol night race in Bristol TN,(NASCAR) right after I lowered it. Then was a daily driver for a couple years before I sold it. Call someone like Stylin Concepts to help you with the parts. Make sure they know it's the old square body style, so they won't get confused. I use to tell the parts houses and mail order places it was a 1987,... just to make sure I got the right parts. Good Luck!
08-21-2007, 08:44 PM | #7 |
Thanks, "low" I'll get right on the job. thanks
