08-18-2007, 01:15 AM | #1 |
angel of cut for z"
when i make the cut for the z" on my 84. should i make it straight up and down or at a slight angel b/c i have seen it done both ways.
08-18-2007, 02:36 AM | #2 |
Re: angel of cut for z"
It will be easier to keep everything lined up with a straight cut.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-18-2007, 04:34 AM | #3 |
i agree make a straight up cut
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
08-18-2007, 07:36 AM | #4 |
The problem with the straight cut is you don't get the proper weld penetration when you join them back together. Flat will work, angled is a little harder but a much stronger weld. Doesn't require the ece frame brace either
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
08-18-2007, 10:03 AM | #5 |
Insert Title Here
if you cut on an angle, wont it mess up the center of the hub? sense it will move up and back or forward, depending on the way you angled it?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
08-18-2007, 10:23 AM | #6 |
Insert Title Here
Heres a ruff job in paint, but wouldnt that be how it would end up, or am i missing something
08-18-2007, 12:12 PM | #7 |
1LoC10 hit the nail on the head ...
08-18-2007, 05:23 PM | #8 |
Hollister, CA.
Straight cut is the CORRECT way to go. If the frame is gusseted/plated correctly, it will look like one continuous frame rail.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-18-2007, 06:10 PM | #9 |
be patient with me as im not too educated on this stuff. i have read oround this forum about the wheel not being centered in the well on some of these trucks. would an angle cut be a way of adjusting this off centered problem when building a frame?
08-18-2007, 07:40 PM | #10 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-18-2007 at 07:41 PM. |
08-18-2007, 09:25 PM | #11 |
I've seen it done like the third example in 1LoC10's drawings to center the wheels in the fenders. Seems like a good idea to me.
