Old 08-18-2007, 07:51 PM   #1
loosecannon39
1960-inline 6
My first post folks:
I am about to buy an ultra clean 60 model short stepside, with granny 4 spd, and inline 6. Can anyone tell me if any of the late model automatic overdrive trannys will bolt up without a special adapter??? I haven't seen the truck yet, but have the word of someone I trust. I am assuming the eng is the old 235, blueflame 6, but not sure. Any help appreciated
REGARDS
DAN
loosecannon39 is offline   Reply With Quote
Old 08-18-2007, 09:16 PM   #2
slow66
slow66's Avatar
Re: 1960-inline 6
Im not sure but you can check here...www.inliners.org... I run a inline 250 w/ 200-4r, I like it.
Jason
slow66 is offline   Reply With Quote
Old 08-19-2007, 01:33 AM   #3
Stepside65
Still Truckless!
Stepside65's Avatar
Re: 1960-inline 6
Welcome from blazin New Mexico.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 08-19-2007, 11:26 AM   #4
loosecannon39
Re: 1960-inline 6
Jason,
Is the 2004r a direct bolt up to the 250??? Swapping to a 250 from the stock 235 shouldn't be too tough.
DAN
Old 08-19-2007, 11:50 AM   #5
slow66
slow66's Avatar
Re: 1960-inline 6
The trans bolts up to the 250 no prob, the 200-4r uses the BOP/Chevy bolt pattern. You just go to workout the TV detent hookup on the carb if you run in stock form.
Old 08-22-2007, 09:50 PM   #6
Tomsriv
Tomsriv's Avatar
Re: 1960-inline 6
I have a 200-4r in mine with a 350. The easy way to do it is to run a non-lockup torque converter.
Tomsriv is offline   Reply With Quote
Old 08-22-2007, 11:24 PM   #7
60ratrod
yes, i do
60ratrod's Avatar
Re: 1960-inline 6
think that a 2 speed powerglyde is a direct bolt up. love those old inlines. so much torque and notoriously tough to kill.
60ratrod is offline   Reply With Quote
Old 08-23-2007, 09:51 AM   #8
jchav62
1962 C-10
jchav62's Avatar
Re: 1960-inline 6
Welcome from NM. Later model tranny's on older sixes require an adapter. On the later 230's, 250's and 292's, the newer tranny's will bolt up directly.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-23-2007, 01:39 PM   #9
fercho71
fercho71's Avatar
Re: 1960-inline 6
from San Diego
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 08-26-2007, 03:35 PM   #10
loosecannon39
Re: 1960-inline 6
TOMSRIV:
350/2004r sounds like a good combo, but if you use a non lockup converter, be careful of your rear end ratio/converter relationship. If your engine rpm while cruising is lower than your stall on the converter, it will slip constantly , and fry everything. If this happens, the solution is to go back to a lockup with some stall, if you are going to hot rod, and install a simple switch to disable the lockup while racing, and switch it back on for cruising.
REGARDS
DAN
