Old 08-18-2007, 08:05 PM   #1
bad6772
Official Site Guitar Shredder
bad6772's Avatar
does this look right?
Name:  c notch2.JPG
Name:  c notch 3.JPG
Name:  c notch1.JPG
Name:  c notch 4.JPG
Name:  c notch 5.JPG
Size:  49.7 KBi should of proly asked this in the suspension area, but i figured i would get more replys here( sorry moderators). i have been working on cleaning my frame/ all morning and welding any holes that are not used.... also started on putting my c notch kit in i got from GMC pauls as many know there is not template and it seems hard to mess up but did i ? i started out getting the frame level front to rear and side to side. with everything level i made a template out of poster board, nad made my cuts... i made shure that the c notch was right in the middle of my axle. and it seems measure out fine, my question is in the first pic.should there be that wide of a gap? i am planning on fully welding it all around and also bolting it. but that gap seems weird to me . are these not made to be center to center? like as the center of the notch with the center of the axel? i hope i didnt cut this wrong... but i think i am over reacting alittle.....(argon getting to me .....any help or if you guys see something i have done wrong please point it out to me, i have no shame i would rather ask and look like a moron than to do this the wrong way and be a moron . thanks tony
bad6772 is offline   Reply With Quote
Old 08-18-2007, 08:08 PM   #2
bad6772
bad6772's Avatar
Re: does this look right?
more pics of notch....if you guys need different angles of pics to see something let me know ill go take pics............by by un used hole...im thinking of doing the whole frame? but my little brass hammer has taken a beating today.................Name:  c notch 6.JPG
Name:  welded holes.JPG
Name:  welded holes 2.JPG
Old 08-18-2007, 09:26 PM   #3
cdowns
cdowns's Avatar
looks to me like the plates should go to the inside of the frame rail to box in that part of the rail for extra strength
Old 08-18-2007, 10:18 PM   #4
bad6772
bad6772's Avatar
Size:  56.6 KBthis is the way i have seen everyone install them. are you saying that i have the left as the right and the right as the left? im pretty shure they dont go that way.im just concerned with the gap. but they dont fit any other way..i think i am being anal about these....i have seen some posted here before, but the weld were already ground smooth.... i got these pics from MISTERE72 he did this a while back looks like mine but there isnt the gap at the top everything else fits flush/w mine
Old 08-18-2007, 10:29 PM   #5
Shane
Shane's Avatar
you installed it the correct way ... but most folks go ahead and drill the holes and bolt it up up before welding. mine looked the same way before I drilled the holes ... the bolts help pull it up "snug" with the frame.
drill it ... bolt it ... weld it ... remove bolts ... weld up bolt holes.
Shane is offline   Reply With Quote
Old 08-18-2007, 10:35 PM   #6
bad6772
bad6772's Avatar
thanks shane.........so i got some grinding to do in the morning.....what the fahell...hey shane..you just plug welded the bolt holes? and did you weld all away around and or box...this is a very thick peice.
Old 08-18-2007, 10:48 PM   #7
Shane
Shane's Avatar
I didn't weld mine at all ... just bolts ... but I have seen it done where folks that DO weld them bolt them up first, then weld around the perimeter/outside of the C notch, remove the bolts and then plug weld the holes ... don't know of anyone that has boxed using this sort of C notch ... guys making their own from 4"-5" tubing box normally box the frame in this area, but thats because there is nothing there other than the tubing. With the bought C notch, you have the section on the side AND the bottom.
You look to be off to a good start thought.
Good Luck!
Old 08-18-2007, 10:54 PM   #8
bad6772
bad6772's Avatar
so you think that if i just bolt it in and weld both sides. ill be pretty strong ? i tell you this kit i got from gmc pauls isnt no cheapie.it is thick steel. i think i will just follow your directions and (after i grind my tac welds i will drill and bolt and just weld all other sides....thanks a ton.cant wait till morning to get back on these...oh and welding the rest of the unused hole.....sheesh thanks shane.........tony
Old 08-18-2007, 11:02 PM   #9
Shane
Shane's Avatar
These aren't really good pics, but shows how mine pulled up with nothing but the bolts.
Honestly, if it was me, I would bolt it, snug it and then weld just around the outside since you already started welding it. I wouldn't bother removing the bolts, unless you are going for the "smooth" look.
Old 08-18-2007, 11:15 PM   #10
bad6772
bad6772's Avatar
i think i will leave the bolts in and just dress my welds really good.... i like the smoothe look.. but i the bolts dont bother me if everything else is clean, they wont stick out to much
