Neighborhood Pickle Slinger
How much fluid is in the...?
Can anyone tell me or direct me to a complete list of fluid quantaties?
I am just about to get my 68 back on the road and want to buy the fluids I need. Everything but the engine and tranny are completely dry. I need Quantaties for the rest. Cooling, Power Steering, Brakes, Rear Diff I have looked myself in different books and owners manuals but all I have found is what kind of fluids are supposed to be used. Thanks!
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 Last edited by blukangoo; 08-19-2007 at 03:13 AM. Reason: had to edit something :-) |
Re: How much fluid is in the...?
This is a GREAT question and I vote that it be put in the FAQ once answered.
sufficiently talented fool
![]() Join Date: Jun 2006
I looked through my restoration packet, and it gives the specs for oil, and coolant. It varies for model and engine size. Coolant can be anywhere from 12 to 20 quarts depending on the engine and options.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
dont have access to my shop right now but i do believe all are listed in the factory service manuals
i know 12bolt and 10bolt rears are a bit less than 2quarts of royal purple
Thanks for the answers everybody.
Being Iīm on a small budget, I donīt want to buy TOO much so I thought I would ask. Petroleum products arenīt that cheap over here. Here are some more infos on the truck. Engine 327 (was about 5 quarts) Tranny TH400/375 (Havenīt filled it up yet because the driveline isnīt back in. It is supposed to be about 10 or 11 Liters with the Torque converter.) 12 Bolt Rear end Standard Power Steering and cooling system Brake cylinder is cast iron and I think a Bendix.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
Should be about 2 quarts in the rear axle, 1 quart of power steering fluid, 2 gallons of coolant, and a quart of brake fluid. That is what I would buy as a start.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 08-19-2007 at 04:33 PM. |
Thanks again. I wrote the amounts down. I guess I will see if they are about right.
