Old 08-19-2007, 09:15 AM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
a/c set up
Just made the maiden voyage this past week with the money pit, even got a legal inspection sticker.
Texas heat and a black truck sure make for a hot ride.
My question is: what A/C compressors will fit in a 68 c10 with a 327? There are plenty of junk yards around and I need to make a trip to finish off some of the final touches and was hoping that a later model A/c set up would work.
rchdrm is offline   Reply With Quote
Old 08-19-2007, 10:36 AM   #2
1970shortbed
Active Member
Re: a/c set up
there is a place in fort woth that sells the complete kit it will contain all you need to install a/c in your truck i got mine from there
the install was pretty straight forward and not that hard at all cant rem the name off my head but if you search aftermarket a/c or a/c you should find all you need on the subject
1970shortbed is offline   Reply With Quote
Old 08-19-2007, 11:12 AM   #3
suville
suville's Avatar
Re: a/c set up
Classic Autoair, gets purty hot here in southern Idaho too! Dun sum research and have decided on this company. Based in Texas or Florida so they should know what theyre doing.
suville is offline   Reply With Quote
