08-19-2007, 11:45 AM | #1 |
Old Time Rodder
longer wheel studs
couldn't find the thread but recently someone asked about longer wheel studs to use with rear disc conversion rotors. I just bought some from Napa part # 641-1578 which I installed on Friday and was pleased with the length. hope this info helps it you are converting to rear disc.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
08-19-2007, 05:48 PM | #2 |
Re: longer wheel studs
thank you ... thank you ... thank you ...
05-01-2011, 12:22 PM | #3 |
here is a little more info:
But the stud numbers I found were: 27883B Raybestos/ 610-258 Dorman/ 641-1578 NAPA Balkamp
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
05-01-2011, 06:55 PM | #4 |
BMW & ASE Master Certified
When I did the c5 rear brake converison, I used the Dorman 610-298.
some spec on the Original stud: Thread Knurl Dia. Length Shoulder 1/2"-20 .535" 1-17/32" 5/16" spec on the 610-258 (mentioned above) Thread Knurl Dia. Length Shoulder 1/2"-20 .536" 1-23/32" 1/4" spec on the 610-298: Thread Knurl Dia. Length Shoulder 1/2"-20 .547" 2" 11/16" clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
