Old 08-19-2007, 12:43 PM   #1
Duro5341
Duro5341's Avatar
Gas tank sizes, and interchangability
Hey guys
I have a 86 K10 LWB which at one point had dual tanks
At the present time it only has the Drvs tank, and it's a 65 Liter tank.
Now I have to replace the sock on the sending unit, as it's completely saturated with crap, and killing fuel pumps, so I figured it's a good time to upgrade.
I was wondering If I could put in a bigger tank, and still use the same straps, and brackets?. I was thinking of a 85 or more lliter tank, what tanks were offered with these trucks, eventually I would like to also get a passenger side tank, and get it working aswell
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 08-19-2007, 07:33 PM   #2
Duro5341
Duro5341's Avatar
Re: Gas tank sizes, and interchangability
Bump^^^^^
Old 08-20-2007, 11:26 AM   #3
rfmaster
rfmaster's Avatar
Duro
You have 2 Choices (16 or 20 Gallon Tank) depending on your wheelbase. Short beds, as far as I know, used 16 gallon tank (43" Long), while 8 foot beds used 20 gallon tanks (56" Long). These tanks are readily available and inexpesnsive. The best part, some are still built in North America, no China made crap.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 08-20-2007, 01:39 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If it is a Long wheelbase you can use either the 16 or 20 tanks, On a short wheel base you can ONLY use the 16 gal tanks.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-23-2007, 09:26 PM   #5
Duro5341
Duro5341's Avatar
I have a LWB, and I know I will fit a 20 gallon under there.....however I was wondering if the bracket stay in the same location, or if they moved?. What is the differerence between the two tanks? is it just length or is it more?
Duro
