08-19-2007, 12:44 PM | #1 |
Oil Pressure 80 Silverado??
I am looking at a 80 Silverado to buy (one owner Az truck) and on the test drive I noticed the oil pressure was (to me) low. The gauge was a 60# high and it was riding in the center, so I am thinking 15-20#, is this about right for a 80 350cid.??
I was also thinking about the 700R from the 80's as a bad transmission, but after all these years it has survived so I guess it is good! This truck is almost flawless but the oil pressure leaves some doubt!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-19-2007, 01:12 PM | #2 |
Re: Oil Pressure 80 Silverado??
At idle mine will be in the center, and at cruise it'll be around the 3/4 mark.
AT minumum it would accept 15PSI at idle. I forget what the minumum for every 1000RPM Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
08-19-2007, 02:49 PM | #3 |
10 psi for every 1000 RPMs
if its a 0-60 gauge and it was in the middle, then you're running about 30 psi. not real sure why you would think 15-20. another thing to keep in mind is the gauges arent always accurate, but will never show a higher pressure in error. as for the 700R4, if its an 80 Silverado, there's no chance that the 700R4 is stock, as the 700R4 didnt come out until 1982 |
08-19-2007, 04:40 PM | #4 |
I guess I just divided it too many times, 30# is more like it!!
The shift indicator has a L1 and L2 so I thought it was a four speed, and that was a 700R, no?
08-19-2007, 06:38 PM | #5 |
Parts and more parts
If you seriously want the truck and truly want to know what the pressure is, mount a manual gauge on it to see, before purchase. What you have told me, sounds good so far.
08-19-2007, 07:18 PM | #6 |
Sounds acceptable to me. Different weights of oil can change the oil pressure, which brings up the old trick of moving to the thicker oil to "tighten" up an engine that is worn.
08-19-2007, 10:18 PM | #7 |
The Crazy Machanic
im at 28 when warmed up at first start im at about 50. and at warmed up and driving around 32.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
