Got Big Block?
Modernized Classic Truck!
Trying to map out a budget for my current project and wanted to get some opinions from those of you that have been down this road before. I have a '69 K5 4x4 Blazer with the CST package that needs a total restore. It came as a auto with no A/C, scroll seat covers on the buckets and rear seat and side panels. No rust in the difficult areas that I've found yet.
Here's my goal for this project: to make a totally reliable, roadworthy vehicle that I can work and play in. No racing no car shows, just work and family cruising. For this particular project I'm not concerned about keeping everything original. My plans are for a modest 2.5"-3" lift with 33" tires on my 15" stock rally's. My question to the experienced bunch is this, knowing that I want this thing to be bullet proof both engine and chassis wise, should I look for a newer suspension components to put under this truck? Obviously front disc brakes would be nice. I'm undecided on whether to try and locate a GenIII / 4L60 engine/tranny combo or not ($$) as the 350 that's in it seems to be in good working order. The Turbo 350 tranny will have to be rebuilt so an overdrive would be nice though... As always, my budget is modest and I need to make every dollar count. Thanks for any input that will help make this project a success. PS. To all the purists, I realize that I have 1 of 49xx blazers made etc... Unfortunately, this truck is what I found and what I have to work with. If it makes you feel better, when I'm finished, this truck will "look" mostly stock on the exterior. Hopefully, it will just drive like a new one. ![]() ![]() thanks!
"Experience is what you get when you didn't get what you wanted." |
Re: Modernized Classic Truck!
It doesnt sound to me like anything you want to do to it will ruin it in any way. I say go for it!...
#3 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#4 | |
They call me the Breeze...
![]() Join Date: Jul 2007
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
Bang for buck, GM carb'd crate motor. The GenIII conversion is not cheap as it is not the cost of the motor that is the problem, it is everything else that has to done to make it work. Sound like you have a decent project. I also have a '69 CST K5. I started out doing what you are, but ended up getting a little more wild with mine as I can't leave anything alone. I now have a LT1/4L80/205 going in it, 3.73 Posi front and rear, 4" custom shackle flip out back, 2.5 lift springs up front, ORD greasable bushings, custom install '03 Burb 13" disc brakes front and rear, 18x10 wheels, 33" M/T tires. Body repair starting after Labor day and will be painted a pearl blue with white top.
Mike
Mike Redpath |
