Old 08-19-2007, 06:07 PM   #1
texas-topper
texas-topper's Avatar
Coolant Temperature Gauge - Needle position when engine is warm
Hi All,
First time poster to the forum and I am looking for a little info. Last weekend I bought a fairly clean, 1978 Chevy Big 10 with 53K original miles. It has the 350-4bbl engine. It seems to be running cool (better then the alternative) and I suspect the thermostat is stuck open.
Could you all tell me where the temperature gauge needle should be pointing when the engine is warmed up? I suspect it should be somewhat to the right of the long, center vertical tick mark on the gauge. Also, let me know what temperature thermostat your running. I believe GM installed 195ºF thermostats, but I am leaning towards putting in an 180ºF to deal with the central Texas heat.
Thanks for the help!
Ken
texas-topper is offline   Reply With Quote
Old 08-19-2007, 07:26 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Coolant Temperature Gauge - Needle position when engine is warm
The stock temperature gauge kind of scares me, especially the ones that just say C on one side and H on the other. The ones that say 100 and 260 arent as bad but you still don't know what the water temp is until it's pegged at 260.
I would go for an aftermarket gauge to at least supplement the stock one.
Running a 180 here in Austin.
Pyrotechnic is offline   Reply With Quote
Old 08-19-2007, 08:19 PM   #3
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by Pyrotechnic View Post
T
Good idea. Any suggestions for a GOOD aftermarket one?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-19-2007, 08:27 PM   #4
Duro5341
Duro5341's Avatar
Mine sits around the 1/4 mark all the time. This is with a new rad, thermostat, heater core, and all hoses. So I would assume this is the proper location
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 08-19-2007, 08:42 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would say a 180* degrees thermostat should be good to run. I would also say to get an after market gauge so u will have a better reading.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-19-2007, 09:13 PM   #6
Pyrotechnic
Autometer is good stuff. I recommend their Autogage line for the value. About the only difference I can tell between them and the Autometer stuff is less variety of models, and they are not valid for race contingency. I own a Oil Pressure, Volts, Water Temp, and Vacuum gauges as well a tachometer and they seem to be quality products. Of course if you have the extra bucks, the Autometer stuff is great and you got a wide selection of styles to choose from.
Here's the gauge pod that I have in my 77. The larger 2 5/8 gauges are really easy to read at a glance. I can snap a pic of the install if anyone is interested. http://www.autometer.com/cat_gaugede...gid=3362&sid=1
I'm also using oil pressure and water temp warning lights since the gauges are not mounted in the dash bezel and I wont always be looking at them. Eventually the plan is to remove the stock gauges and replace them with stock idiot lights and have these sending units trigger them. http://www.daymotorsports.com/product/282/c/C89/
Old 08-19-2007, 09:29 PM   #7
texas-topper
Duro
Thanks for all the replies. Like Duro said in his post, my needle sets on the first tick mark(1/4 mark) from C. I plan to change the thermostat out and while I have the radiator drained I think I will replace the water pump as well. This truck still has the original water pump on it, which I think should be retired after nearly 30 years of service,...just to be safe. I think I also will borrow a pyrometer from work so I can see what the temperatures are at the radiator and the thermostat housing.
I agree that a good aftermarket temp gauge is in order. I used Autometer Sport Comp gauges on my '76 Monte Carlo restoration and really liked the look and quality of them. I will most likely put one on this truck as well. The current gauge is just as Pyrotechnic described "ones that just say C on one side and H on the other."
Ken
